It is currently Fri Apr 24, 2015 4:41 pm
 Post subject: C++ file parsing help
PostPosted: Fri Feb 20, 2009 12:02 am
I'm trying to use the fstream to parse a text file. I've looked at sample code and the compiler (I'm using MS VS 2008) is fine. But I have a feeling it's not even reading the file I'm wanting it to (it's a simple text file).
#include <iostream>
#include <fstream>
#include "file_parser.h"
using namespace std;
void file_parser::read_file()
   int file_length;
   fstream asm_code;
   asm_code.open(file_name.c_str(),ios_base::binary);
   asm_code.seekg(0,ios_base::end);
   file_length = asm_code.tellg();
   asm_code.seekg(0,ios_base::beg);
   buffer = new char[file_length];
   asm_code.read(buffer,file_length);
   asm_code.close();
Basically file_length isn't getting the length of the text file, which is what I want. I've made sure that the file name is right and the file itself is in the same directory as the executable (<project>/debug). Or if there's a way of copying the contents of the text file without knowing its length, that'd be fine.
On a personal note, I want to go back to C# :(
PostPosted: Fri Feb 20, 2009 5:03 am
Try something like this...
StreamReader *reader=new  StreamReader(textFile);
while(reader->Peek() != -1);
KB 307398
Why are you doing it in C++? C# and VB.NET are much better suited to these kinds of tasks, IMO.
PostPosted: Fri Feb 20, 2009 6:45 am
Thanks, I'll give that a shot. It's for a class. I've gone from using VS2008 C# to programming in UNIX shells. But hey, good experience. I'm developing the code in VS2008 anyways because I don't want to work with g++ though.
PostPosted: Fri Feb 20, 2009 6:59 am
Uh... I don't know that stuff developed VS 2k8 stuff will work under unix. What class is it for? An operating systems type class?
You will want to probably avoid VS for this. Try Dev C++ or something maybe?
PostPosted: Fri Feb 20, 2009 8:18 am
It's a system's programming class. And it'll work. VS has basically reverted to "you're on your own" mode since Intellisense doesn't work unless I'm calling a method and all the new files start off blank. Plus a few other people are doing it. Unless VS2008's compiler does some different things compared to g++ that are drastic, I don't think it'll be a problem.
PostPosted: Fri Feb 20, 2009 8:53 am
Well, good luck to you then...
All I am saying is that .NET is very different from GCC/G++ and if you are targeting a UNIX/Linux platform, it makes sense to use the compiler tools for that platform.
I mean, it isn't like I ever took that class before... :roll:
PostPosted: Fri Feb 20, 2009 9:49 am
The problem still is that it can't read the file. It won't even open it. I've basically tried something simple like:
#include <iostream>
#include <fstream>
#include <string>
int main()
   ifstream code;
   code.open("sample.txt", ios::in);
   if (!code)
     cerr << "Can't open input file " << endl;
And the if is always triggered. Argh, what I get for pretty much not caring about C++ for two years.
EDIT:
Tried compiling it with g++ with an else statement. It worked.
*sighs* looks like I have to learn to debug with g++ then.
