It is currently Thu Jan 29, 2015 9:55 am
 Post subject: BAtch Program issue
PostPosted: Sat Jan 01, 2005 6:30 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Practicing batch programming and I was just writing a quick junk cleaner program........
cls
REM ****************************
REM *   Simple Drive Cleaner            *
REM * Will Delete-                            *
REM * > Cookies                              *
REM * > Temporary Files                   *
REM * > Offline Web Pages                *
REM * > Download Program Files       *
REM Press Any key to continue......
PAUSE
deltree /y C:\WINDOWS\Temp *.*
deltree /y C:\WINDOWS\Downloaded Program Files*.*
deltree /y C:\WINDOWS\Offline Web Pages*.*
deltree /y C:\Documents and Settings\Cookies*.*
deltree /y C:\Documents and Settings\Administrator\Cookies*.*
REM Drive clean completed
REM Press Any Key to Exit Program......
PAUSE
EXIT
But when i run the program the text at the beginning dosent show up. It skips strait to " Press any key to continue" Any clue?
PostPosted: Sat Jan 01, 2005 6:31 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
sorry^^ my star border got screwed up
PostPosted: Sat Jan 01, 2005 7:39 pm
In the lab!
In the lab!
try echo instead of rem
PostPosted: Sat Jan 01, 2005 7:55 pm
Team Member Top 100
Team Member Top 100
Dexter is right --
Rem is for comments.
Use Echo to echo text.
PostPosted: Sun Jan 02, 2005 2:21 am
Bitchin' Fast 3D Z8000*
Kybo_Ren wrote:
Dexter is right --
I was about to correct you and say that REM is for remarks - it must be getting late! Time for bed. :)
 Post subject: Re: BAtch Program issue
PostPosted: Sun Jan 02, 2005 2:23 am
cls
REM * > Cookies                              *
PAUSE
PAUSE
EXIT
Now challange yourself some more Gamerfreak and do the same program in two more languages. For extra credit, also include support for one or more operating systems. And be sure to check that your current batch file actually works as intended.
PostPosted: Fri Jan 14, 2005 9:49 pm
I am new to programming too. What language is he using there, looks like some DOS stuff.
Would it be even easier to use an apostrophe ' instead of REM for documenting?
PostPosted: Fri Jan 14, 2005 9:50 pm
Team Member Top 100
Team Member Top 100
It's DOS shell scripting, basically.
PostPosted: Sun Jan 16, 2005 10:25 pm
Not really. It would save a two characters is all. Of course, he could use the ' initially and then do a replace all to REM as well.
