It is currently Sat Feb 28, 2015 9:26 pm
 Post subject: Looking for a program to copy 3 files continuously
PostPosted: Fri Jan 30, 2009 6:42 pm
I need a program that can copy 3 small files (x, x1, x2 - all less than 2kb) once every second, possibly more often, from directory x to directory y on the same machine. No networking support required.
Anyone know of one? Preferably free? xstarter expired on me and didnt work so well. Any ideas?
PostPosted: Fri Jan 30, 2009 8:37 pm
Are you just testing a connection or what?
PostPosted: Sat Jan 31, 2009 12:01 am
Might be able to have a script running in the background doing the copying.
PostPosted: Sat Jan 31, 2009 7:17 am
I was thinking a script could handle it too, but I don't know much about scripting environments in windows.
alex the less info I post the easier it will be to find a solution.
PostPosted: Sat Jan 31, 2009 9:29 am
You want Karen's Replicator
PostPosted: Mon Feb 02, 2009 10:19 am
No I don't, the fastest it can apply a job is once every minute. Same with most other backup applications like cobian etc. I specifically stated every second or faster.
Honestly whats so hard about reading a few sentences? I even used spell check, punctuation and capitalization.
PostPosted: Mon Feb 02, 2009 10:45 am
First off, FU!
Second off, change the frequency to seconds with her posted hack!
PostPosted: Mon Feb 02, 2009 12:20 pm
Save as a .vbs. Run as you wish, create a scheduled task in Windows, whatever.
Option Explicit
Dim objFSO, objFileCopy1, objFileCopy2, objFileCopy3
Dim strFilePath1, strFilePath2, strFilePath3
Dim strTargetFilePath1, strTargetFilePath2, strTargetFilePath3
strFilePath1 = "c:\file1.txt"
strFilePath2 = "c:\file1.txt"
strFilePath3 = "c:\file1.txt"
strTargetFilePath1 = "d:\file1.txt"
strTargetFilePath2 = "d:\file1.txt"
strTargetFilePath3 = "d:\file1.txt"
' Copy the file to its destination, do this 3 times
For count = 0 to 3
   'Set up objects
   Set objFileCopy1 = objFSO.GetFile(strFilePath1)
   Set objFileCopy2 = objFSO.GetFile(strFilePath2)
   Set objFileCopy3 = objFSO.GetFile(strFilePath3)
   'Do the copy
   objFileCopy1.Copy (strTargetFilePath1)
   objFileCopy2.Copy (strTargetFilePath2)
   objFileCopy3.Copy (strTargetFilePath3)
   'Sleep for 3 seconds
   WScript.sleep 3
Next
Wscript.Quit
PostPosted: Mon Feb 02, 2009 3:12 pm
kleinkinstein wrote:
First off, FU!
There's a hack? You have to hack the program to get seconds? I didn't see any mention of that on the page, or in your post.
Crashtech thank you, can I use decimals in place of the seconds value? (IE 1.1, .5, etc)
PostPosted: Mon Feb 02, 2009 4:03 pm
Nuts I'm getting an error with the script crash. First it said count was undefined so I added "dim count" to the top hoping that was the proper syntax to create the variable.
Now the problem is as follows:
"Script: C:\pathhere\script.vbs
Line 19
Char 4
Error: Object required: "
Code: 800A01A8
Source: Microsoft VBScript runtime error"
Any ideas? I'm guessing something in the set up objects section is improperly formatted.
Thanks again.
PostPosted: Mon Feb 02, 2009 4:08 pm
Try this. I added the count var like you mentioned in your PM.
Option Explicit
Dim count
'''''''''' ADDED ''''''''''
Set objFSO = CreateObject("Scripting.FileSystemObject")
For count = 0 to 3
   'Set up objects
   'Do the copy
   WScript.sleep 3
Next
Wscript.Quit
PostPosted: Mon Feb 02, 2009 4:52 pm
It's working now thanks. Just a few more questions:
1) Can I use values with decimals instead of whole seconds?
2) Whats the formatting for a never ending loop in VBS? At the moment it will just copy the files 3 times it looks like. I need it to run for 5 to 50 minutes. I mean I guess I could just do that math and set it from 0 to (X minutes times 60 with a 1 second sleep) but I was hoping for a different method.
Or maybe something that pops up a warning that the script isnt running anymore?
PostPosted: Mon Feb 02, 2009 6:26 pm
I think the sleep function actually takes milliseconds. So that is my bad.
http://mikesalsbury.com/2005/06/vbscrip ... ction.html
I really don't know that a never-ending loop is a really good idea. I guess you could try to have it run till you hit a key combination?
I haven't written VBS in quite a while, so I am not sure how to go about it. You probably could use a timer and edit the file before you run it to change how long it runs for?
PostPosted: Mon Feb 02, 2009 7:42 pm
at the moment I just wrote a basic loop to ask if it should run again like so:
i=0
do while i < 1
For count = 0 to 900
   'Set up objects
   'Do the copy
   'Sleep for 1 second
   WScript.sleep 1
Next
'Checks if you want to run the loop again
dim answer
answer=MsgBox("Finished, run again?!",4,"Loop")
if answer = 6 then
i=0
else
i = 1
end if
loop
Lol I figured it wasn't seconds, considering it took less than 5 seconds to complete when i set count to go to 900. I should have remembered vb likes milliseconds from my VB days >_<
PostPosted: Tue Feb 03, 2009 5:18 am
I didn't even realize it. I yanked some sample code and dropped it in there.
I am sure you could set something basic that will ask the target time to run and do some math for you?
PostPosted: Tue Feb 03, 2009 3:04 pm
You underestimate my laziness when it comes to programming. I gave up on CS along time ago as not worth it. Scripting is kinda more useless to me because there are so many versions of so many types of scripting. I can usually work out the gist of a script in my head anyways.
I found a value that gives me 16~ minutes of run time and that should do me just fine. Thankfully it doesn't tell the file system to create x(1).txt, x(2).txt ad infinitum.... or I'd have one hell of a full dir right now :P
Ty for all the help.
PostPosted: Thu Feb 05, 2009 3:57 pm
now let me show you the easy way.. =)
simplest method is to use a batch file. Three lines of code basically to copy three files. Only problem is that there isn't any batch file command in xp or vista to "sleep" or "delay" or whatever. That can be remedied with a few more lines of c++.
Batch file: copy_file.bat
@ECHO OFF
copy C:\files\file1.txt C:\newlocation\file1.txt
copy C:\files\file2.txt C:\newlocation\file2.txt
copy C:\files\file3.txt C:\newlocation\file3.txt
EXIT
C++ to automate the sleep - run.cpp
#include <stdlib.h>
#include <windows.h>
int main() {
  while(1)
  system("copy_file.bat");
  Sleep(1000);
Download the .exe for the c++ code here.
Name the batch file "copy_file.bat" and save it in the same folder as run.exe. When you double click the executable it will start copying the files every one second. Obviously any extras would be easy to add to the c++ code... not sure exactly what you'd want though. It's even possible to have the c++ program ask which files you want and automatically generate the accompanying batch file.
I can make the delay between copies shorter than one second, but I imagine too short and we'd start impacting disk performance?
