It is currently Sat Feb 28, 2015 5:22 pm
 Post subject: Two questions about file manipulation in C++
PostPosted: Wed Dec 10, 2008 8:55 pm
I have two questions about file management in C++ :
Firstly, how can I copy a file to another directory. Should I use the System() command, or is there a better way?
Second, Is there any way to copy to another directory the executable itself, that is, the file currently running the commands? I cannot rely on the name of the file either, as this may be changed.
Thanks in advance for your help.
PostPosted: Thu Dec 11, 2008 4:41 am
in C++.NET
http://msdn.microsoft.com/en-us/library ... copy(VS.71).aspx
In normal C++
http://www.rohitab.com/discuss/index.ph ... t&p=126059
you should be able to copy any file... however, you do need to know the name of the specific file you wish to copy.
Use this to get the exe name?
http://blogs.msdn.com/brada/archive/200 ... 13620.aspx
then use the above method to copy it?
PostPosted: Thu Dec 11, 2008 5:22 am
argv[0] should hold the name of the application ... hopefully, that is the filename that you need.
I think that Crash covered the HOWTO pretty well.
PostPosted: Thu Dec 11, 2008 4:45 pm
I put that into code, but I get an error on the CopyFile() function about the arguments I'm using. It's probably a n00bish error I know :)
#include <iostream>
#include <cstdlib>
#include "windows.h"
using namespace std;
int main(int *argc, char *argv[]) {
   cout << "Hi there!" << endl << endl;
   cout << argv[0];
   string exe_name = string(argv[0]);
   CopyFile(exe_name,"C:\\test.exe");
   cout << "Copy finished." << endl << endl;
   system("pause");
   return 0;
PostPosted: Thu Dec 11, 2008 10:32 pm
UPDATE: recoded it in C#.NET and it worked fine.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace SelfCopying
    class Program
        static void Main(string[] args)
            String exeName = Environment.GetCommandLineArgs()[0];
            if (exeName.Equals("C:\\test.exe"))
                Console.WriteLine("This program has already been copied!");
                Console.WriteLine("Move it to another location, and then run it.");
                Console.WriteLine("Press <enter> to exit the program.");
            else
                Console.WriteLine(exeName + "\n\n");
                System.IO.File.Copy(exeName, "C:\\test.exe", true);
                Console.WriteLine("Copy successful.\n\nPress <enter> to exit.");
            Console.ReadLine();
