It is currently Mon Mar 30, 2015 4:28 pm
 Post subject: Complete Beginner with Simple Question
PostPosted: Sat Dec 06, 2008 5:48 pm
I have been googling this for the last 1/2 hour but can't seem to find a definitive answer. As I said I'm basically a complete beginner and I'm trying to run the most basic of programs (my first one :-) ) a Hello World Program. When i try and run it a window pops up for a split second with the Hello World text but I can not find out how to pause it at this window instead of it simply closing right away.
PostPosted: Sat Dec 06, 2008 6:58 pm
What language? There are a lot of things you can do. Have you tried running the program from the command line?
PostPosted: Sat Dec 06, 2008 9:33 pm
Well, in my experience, C++, Java, Visual Basic, and possibly others will exit immediately after the last statement has executed. This behavior in the Hello World program can cause you to think that the program is malfunctioning, but it is most likely not. To combat this behavior, at the end of your program, you can put whatever statement in that language that reads text into a variable. For instance, in Java:
new java.util.Scanner(System.in).nextLine();
Or C++ :
int x;
cin >> x;
Or visual basic:
Console.ReadLine()
Hope this helps.
PostPosted: Sat Dec 06, 2008 10:12 pm
Sorry about that, it's in C++ and I was doing it in Bloodshed...I tried what you said Quertior and it didn't work but then I went and used the same thing in Microsofts Visual C++ and it worked fine. Any reason for it working in one and not the other?
 Post subject: program exiting without pause
PostPosted: Sun Dec 07, 2008 12:04 am
If you are using Windows, your problem is that the command window will close when the program exits. insert this into the bottom of your code, right above the return statement (assuming main() returns a value)...
// system command to pause execution
system("PAUSE");
That should solve your problem.
 Post subject: Re: program exiting without pause
PostPosted: Sun Dec 07, 2008 11:36 am
system("PAUSE");
...And in order to use the system() function, you need to put at the top of your program:
#include "cstdlib.h"
PostPosted: Wed Dec 17, 2008 8:49 pm
you have to put return 0; at the end of the program
PostPosted: Wed Dec 17, 2008 10:01 pm
Actually any int will work, but 0 is the standard.
PostPosted: Thu Dec 18, 2008 11:24 am
Monkey Federation (Top 10)*
The return 0; is simply the return code for the program. If you execute notepad.exe and it does not fail you should get a return of 0, if there are errors the code will change and is useful for debugging.
The return code of 0 is a standard success, any other return code is specific to the application.
