It is currently Thu Jan 29, 2015 7:58 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 09, 2008 6:33 pm
never mind guys i found out how they work:
#include <iostream>
#include <string>
using namespace std;
int main()
char a[20];
cout<<"enter a string: ";
cin.get(a, 20);
cout<<a<<endl;
return 0;
PostPosted: Tue Dec 09, 2008 6:42 pm
wow i actually got it. God dam im lazy all i needed was to read the god dam book. Thank you guys for helping me out.
#include <iostream>
#include <string>
#include <cctype>
int main()
char a[6];
cin.get(a, 6);
cout<<a<<endl;
for (int i=0; i<6; i++)
a[i] = toupper(a[i]);
cout<<a<<endl;
return 0;
PostPosted: Tue Dec 09, 2008 8:53 pm
im getting this error when i run my program:
stringProgram (extra credit).obj : error LNK2028: unresolved token (0A00028A) "void __cdecl printThird(char * const)" (?printThird@@$$FYAXQAD@Z) referenced in function "int __cdecl main(void)" (?main@@$$HYAHXZ)
stringProgram (extra credit).obj : error LNK2028: unresolved token (0A000296) "void __cdecl reverseString(char * const)" (?reverseString@@$$FYAXQAD@Z) referenced in function "int __cdecl main(void)" (?main@@$$HYAHXZ)
stringProgram (extra credit).obj : error LNK2019: unresolved external symbol "void __cdecl printThird(char * const)" (?printThird@@$$FYAXQAD@Z) referenced in function "int __cdecl main(void)" (?main@@$$HYAHXZ)
stringProgram (extra credit).obj : error LNK2019: unresolved external symbol "void __cdecl reverseString(char * const)" (?reverseString@@$$FYAXQAD@Z) referenced in function "int __cdecl main(void)" (?main@@$$HYAHXZ)
#include <iostream>
#include <cctype>
#include "prototypes.h"
int main()
   int choice;
   char a[20];
   cin.get(a, 20);
   do{
   cout<<"1. Convert the string to uppercase\n"
         <<"2. convert the string to lowercase\n"
         <<"3. Print the string\n"
         <<"4. reverse the string\n"
         <<"5. print out the third letter of the string\n"
         <<"6. exit" <<endl;
   cout<<"\n"<<"Enter a choice: ";
   cin>> choice;
   switch (choice)
         case 1:
            convertToupper(a);
            break;
         case 2:
            convertTolower(a);
            break;
         case 3:
            printString(a);
            break;
         case 4:
            reverseString(a);
            break;
         case 5:
            printThird(a);
            break;
         case 6:
            exit(0);
            break;
   }while(choice !=6);
   return 0;
void convertToupper(char arr[])
   for (int i=0; i<20; i++)
      arr[i] = toupper(arr[i]);
void convertTolower(char arr[])
      arr[i] = tolower(arr[i]);
void printString(char arr[])
   cout<<arr<<endl;
PostPosted: Tue Dec 09, 2008 10:16 pm
By saying char a[6], you are defining an array of chars of length 6 (btw, this is how the string class stores strings internally). Say the user enters "pneumonoultramicroscopicsilicovolcanoconiosis". This is 45 letters, which is a lot more than six. Therefore, you can't put a string into a fixed size array of chars without causing size problems. After all, the end user is the most unpredictable part of programming :)
PostPosted: Wed Dec 10, 2008 9:07 am
SO how would i go about that? Do i leave the subscript blank?
PostPosted: Wed Dec 10, 2008 10:50 am
If you want a string, use a string.
A string is a special char array. When you create an array, you must define its size before you use it. If you want to increase the size of your array, you have to create a new array of the new size and copy the contents of your old array into it.
A string is a mutable array. If you create a string and initialise it with the value 'bob', you have create a char array with 3 spaces. If you then change the value of the string to 'cheese', the string is automatically resized to hold the new value without you having to do anything. That's why we say that a string is 'mostly' a char array. Think of it as a char array on steroids ... it does the heavy lifting for you.
It is important for you to understand the difference between a string (an array of characters) and an array of strings (an array of char arrays). The latter is a two-dimensional array.
To fix your problem, you need to use a string where you are using a char[].
PostPosted: Wed Dec 10, 2008 4:34 pm
He nailed it again. It would behoove you to use strings in this application instead of char arrays, which are all but useless in the presence of strings...
PostPosted: Thu Dec 11, 2008 4:43 am
Uhm, what?
I can't help but think this is a terribly inaccurate statement. Chars and char arrays probably get used far more often than actual strings do in most C/C++ that I have seen. I could be wrong, but my experience shows me otherwise.
In his application, I agree, strings are the best way to go. If you mean that the char arrays were "useless" in this scenario, then that is "okay" (although calling anything in programming useless is probably not totally correct... unless you are talking about GOTO :) )
PostPosted: Thu Dec 11, 2008 5:20 am
I think he meant that it is best to use a string where possible rather than a char[].
As opposed to saying 'characters arrays are useless' which is, of course, kinda silly.
PostPosted: Thu Dec 11, 2008 5:34 am
Without char arrays, there would be no strings :)
PostPosted: Thu Dec 11, 2008 5:44 am
Without fire, nothing would ever be charred!
PostPosted: Fri Dec 12, 2008 5:51 pm
I changed it to string a[20] now it says cannot convert parameter 1 from std::string to int
PostPosted: Sat Dec 13, 2008 12:47 pm
Because the best part about strings as opposed to char arrays is that you don't need to specify a length; the string resizes automatically. Correct syntax:
string str;
//or
string str("");
PostPosted: Wed Jan 14, 2009 8:34 pm
I took another "stab" at this problem after finishing the chapter on arrays and strings. Here's my final working code:
#include <iostream>
#include <string>
#include <cctype>
string upper(string, int );
string lower(string, int);
string reverse(string, int );
void printstr(string);
void printThird(string);
int main()
   string word;
   int size, choice;
   cout<<"Enter a word: ";
   cin>>word;
   size= word.length();
    do{
         <<"6. exit" <<endl;
            cin>> choice;
         switch (choice)
         case 1:
            word= upper(word, size);
            break;
         case 2:
            word= lower(word, size);
         break;
         case 3:
            printstr(word);
            break;
       case 4:
           word= reverse(word, size);
           break;
       case 5:
          printThird(word);
           break;
       case 6:
          exit(0);
           }while(choice < 6);
   return 0;
string upper(string name, int length)
   int i;
   for (i=0; i<length; i++)
      name[i]=toupper(name[i]);
   return name;
string lower(string name, int length)
   int i;
   for( i=0; i<length; i++)
      name[i]=tolower(name[i]);
   return name;
string reverse(string name, int length)
   int i=(length-1);
   for( i; i>=0; i--)
      cout<<name[i];
   return name;
void printstr(string name)
   cout<<name<<endl;
void printThird(string name)
   cout<<name[2]<<endl;
