It is currently Sun Mar 01, 2015 11:51 am
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2  Next
 Post subject: can i get a hand here please
PostPosted: Wed Dec 03, 2008 11:28 am
This is another hw assaignment.
Write a program that ask user to enter a string. Then write a loop that prompt user options:
1. Convert the string to uppercase
2. convert the string to lowercase
3. Print the string
4. reverse the string
5. print out the third letter of the string
6. exit
Heres my code: (prototypes are on a separate header file)
#include <iostream>
#include <iomanip>
#include <string>
#include <cctype>
#include "prototypes.h"
using namespace std;
string word;
int choice;
int main()
   cout<<"Enter a word: ";
   cin>> word;
   do{
           cout<<"1. Convert the string to uppercase\n"
         <<"2. convert the string to lowercase\n"
         <<"3. Print the string\n"
         <<"4. reverse the string\n"
         <<"5. print out the third letter of the string\n"
         <<"6. exit" <<endl;
            cin>> choice;
         switch (choice)
         case 1:
            convertTOUPPER();
            break;
         case 2:
            convertTOLOWER();
         case 3:
            printSTRING();
            break;
           }while(choice < 6);
         return 0;
void convertTOUPPER()
   for (int i =0; i < word.length(); i++)
      word[i] = word[toupper(i)];
   menu();
void convertTOLOWER(string word)
   menu();
void printSTRING()
   cout<<word[2]<<endl;
   menu();
void menu()
   do{
         <<"6. exit" <<endl;
            cin>> choice;
   }while(choice < 6);
Im having trouble using the toupper function to convert a string.
PostPosted: Wed Dec 03, 2008 11:31 am
What kind of trouble?
PostPosted: Wed Dec 03, 2008 11:49 am
   menu();
How about?
      word[i] = toupper(word[i]);
   menu();
See here
PostPosted: Wed Dec 03, 2008 1:03 pm
As Crashtech indicated, you're using the function call incorrectly.
You are coding:
The function call should be in the format:
functionname(value) (performs the functionname function on the value)
What you are doing there with word[toupper(i)] is a bit mangled, but essentially something in the format:
value(functionname) (performs the value on the functionname, which doesn't work too well)
This is why it is failing (incidentally, it affects the toLower call in your code as well).
PostPosted: Wed Dec 03, 2008 3:37 pm
why doesnt my printSTRING() function work?
void printSTRING()
cout<<word[0];
menu();
Wouldnt that print out the first element of array word?
PostPosted: Wed Dec 03, 2008 4:19 pm
What is it doing for you? I would think it would give the first character of whatever word you keyed in.
PostPosted: Wed Dec 03, 2008 4:22 pm
But how does it know what "word" is? I do not see word passed a a parameter to the function.
PostPosted: Wed Dec 03, 2008 5:04 pm
i put string word; as a global. for example, user inputs "hello" and it assigns it to variable word[1]. word[0] is going to = hello, correct? so if word[0] = hello i want to pass word which is global to the printSTRING function. And when its passed to the function i want it to convert the string to upper case. IIt looks like i cant do it this way: cin>> word;
word = toupper(word);
PostPosted: Wed Dec 03, 2008 5:21 pm
No. if the user enters "hello" then word (without [] ) = hello.
Remember that the [] is used to refer to individual characters, so word[0] = 'h', word[1] = 'e', etc.
PostPosted: Wed Dec 03, 2008 5:42 pm
no word[0] = hello. its a string.
PostPosted: Wed Dec 03, 2008 6:12 pm
Yes... in the code posted above (at least), word is most definitely a string and not an array. But you contradicted yourself where you said that word[0] = hello. If word were a String array, then word[0] would equal hello. But since word is only a single string, whatever you do using the [] operator will only return a single character. word[0] = 'h'. Q.E.D.
P.S.: It's confusing how word is a global variable that is used in convertTOUPPER but word is overridden in the function convertTOLOWER.
Additionally, since in convertTOLOWER, you neither return word nor make word a reference parameter, that will not change word at all.
PostPosted: Thu Dec 04, 2008 5:21 am
A string is an array of characters. word[0] pulls the first char from the string.
You want an array of Strings if you want to pull out the first word in that fashion.
You also want to stop using global variables. Learn to pass variables to functions.
PostPosted: Thu Dec 04, 2008 10:07 am
Monkey Federation (Top 10)*
speaking of global variables.
string var1 = "But they are soooooo easy!"
therefore:
var1[0] = B
var1[1] = u
var1[2] = t
var1[3] =
var1[4] = t
var1[5] = h
var1[6] = e
var1[7] = y
var1[8] =
var1[9] = a
var1[10] = r
var1[11] = e
var1[12] =
var1[13] = s
var1[14] = o
var1[15] = o
var1[16] = o
var1[17] = o
var1[18] = o
var1[19] =
var1[20] = e
var1[21] = a
var1[22] = s
var1[23] = y
var1[24] = !
and var1.length() will equal 25
PostPosted: Sun Dec 07, 2008 5:32 pm
CrashTECH wrote:
   menu();
How about?
   menu();
See here
i did that and it doesnt convert it to a uppercase h.
PostPosted: Sun Dec 07, 2008 5:39 pm
and how come when i do this:
#include <iostream>
#include <cctype>
#include <string>
int main()
string word;
word = "hello";
string a[5];
a[0] =word;
cout<<a[0]<<endl;
return 0;
it prints out hello.
PostPosted: Sun Dec 07, 2008 5:44 pm
#include <iostream>
#include <cctype>
#include <string>
int main()
string word;
word = "hello";
string a[5];
a[0] =word;
cout<<a[0]<<endl;
return 0;
Because the statement string a[5] creates an array of strings with 5 slots numbered 0-4. This means that you can allocate word to a[0] and print it without any problems.
PostPosted: Mon Dec 08, 2008 8:14 am
#include <iostream>
#include <cctype>
#include <string>
int main()
string word;
word = "hello";
string a[5];
a[0] =word;
cout<<a[0]<<endl;
return 0;
ok then, so why you said earlier that a[0] would be 'h'?
PostPosted: Mon Dec 08, 2008 8:39 am
A string is an array of chars (characters).
Quertior defined a string variable called 'word' and assign it the value 'hello', then the string looks like this:
word[0]='h'
word[1]='e'
word[2]='l'
word[3]='l'
word[4]='o'
He then defined an array of 5 strings called 'a' ( string a[5]; ). He assigned the string in the first position of the array ( a[0] ) the same value as the string variable 'word' ( a[0] = word; ).
At this point, a[] looks like this:
a[0]='hello';
a[1]='';
a[2]='';
a[3]='';
a[4]='';
When he said a[0] would be 'h', he was referring to your code, not his.
PostPosted: Mon Dec 08, 2008 4:05 pm
He nailed it.
PostPosted: Tue Dec 09, 2008 5:15 pm
i dont get it. Wy doesnt this work:
#include <iostream>
#include <string>
int main()
     string word;
     cout<<"enter word: ";
cin>> word;
char a[6] = word;
cout<<a[0]<<endl;
return 0;
