It is currently Sun May 03, 2015 2:14 pm
 Post subject: semaphores problem.. (using gcc on Solaris)
PostPosted: Sun Dec 26, 2004 7:41 pm
Hey I'm working on an assignment and am having some trouble using semaphores:
I've initialized them such:
struct sembuf declock, inclock, setinit;
sem_key = ftok(....);
semid = semget(semkey, SET_SIZE, PERMS|IPC_CREAT|IPC_EXCL);
set_sembuf_struct(&setinit, 1, value, 0);
semop(semid, &setinit, 1);
set_sembuf_struct(&inclock, 0, 1, 0);
semop(semid, &inclock, 1);
everything appears to go fine until I try using semop:
semop(semid, declock, 1); /* a decrement */
and here's the set_sembuf_struct function:
void set_sembuf_struct(struct sembuf *s, int num, int op, int flg)
s->sem_num = (short) num;
s->sem_op = op;
s->sem_flg = flg;
return;
heres my gcc output:
1.c: In function `main':
1.c:32: warning: comparison between pointer and integer
1.c:35: error: incompatible type for argument 2 of `semop'
Any help would be SUPERBLY APPRECIATED, THANKS!!!
PostPosted: Sun Dec 26, 2004 10:36 pm
Team Member Top 100
Team Member Top 100
Change that to
semop(semid, &declock, 1); /* a decrement */
I see you did it on all your others, so it looks like it was just a typo :)
Learn to read your compiler's error messages -- they are quite useful ;)
PS- use code tags, please.
PostPosted: Mon Dec 27, 2004 3:07 pm
oh, my mistake!
Thanks a lot - it worked like a charm!
PostPosted: Mon Dec 27, 2004 3:59 pm
Team Member Top 100
Team Member Top 100
Any time :)
PostPosted: Wed Dec 29, 2004 2:22 pm
Bitchin' Fast 3D Z8000*
In the future, please, please, use the code tags. No one likes reading that unformated code!!! I'm damn near to the point of refusing to help people because it is such a pita to read (and it only takes the poster two seconds to add the tags which benefits everyone).
