It is currently Wed Jun 19, 2013 4:43 am
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Feb 06, 2009 2:16 pm
Well, if you're really interested, here's the code from Integer.parseInt().
(FYI, you probably won't understand all of it, I certainly don't :) )
public static int parseInt(String s, int radix)
      throws NumberFormatException
        if (s == null) {
            throw new NumberFormatException("null");
   if (radix < Character.MIN_RADIX) {
       throw new NumberFormatException("radix " + radix +
                   " less than Character.MIN_RADIX");
   if (radix > Character.MAX_RADIX) {
                   " greater than Character.MAX_RADIX");
   int result = 0;
   boolean negative = false;
   int i = 0, max = s.length();
   int limit;
   int multmin;
   int digit;
   if (max > 0) {
       if (s.charAt(0) == '-') {
      negative = true;
      limit = Integer.MIN_VALUE;
      i++;
       } else {
      limit = -Integer.MAX_VALUE;
       multmin = limit / radix;
       if (i < max) {
      digit = Character.digit(s.charAt(i++),radix);
      if (digit < 0) {
          throw NumberFormatException.forInputString(s);
      } else {
          result = -digit;
       while (i < max) {
      // Accumulating negatively avoids surprises near MAX_VALUE
      if (digit < 0) {
      if (result < multmin) {
      result *= radix;
      if (result < limit + digit) {
      result -= digit;
   } else {
   if (negative) {
       if (i > 1) {
      return result;
       } else {   /* Only got "-" */
   } else {
       return -result;
PostPosted: Tue Mar 03, 2009 1:24 pm
So next I received an assignment that I am to parse an entire text file for any combination of the two letters G and B right next to each other.
This is going to be tough (For me anyways)
There are several ways I can do this I think. I could run the whole loops as follows
Loop Until bottom line has been reached{
{     If GG = token(?)
               G += 2
       Elseif GB = token(?)
               G++
               B++
sample++
and so on and so forth. There is probably a better method but I think I'll go with that one
PostPosted: Tue Mar 03, 2009 2:42 pm
Do you know how to use Regex?
PostPosted: Tue Mar 03, 2009 2:52 pm
No I do not.
PostPosted: Tue Mar 03, 2009 3:49 pm
OK, then your method is probably the best.
PostPosted: Fri Mar 06, 2009 9:28 pm
Fixed those issues. Took me until 12:30 A.M. here but yeah. I was doing it completely wrong and slow.
The program is barely recognizable from what it used to be :P
PostPosted: Sat Mar 07, 2009 12:09 pm
LOL good job man.
PostPosted: Sat Mar 07, 2009 3:27 pm
Quertior wrote:
LOL good job man.
it was a new assignment. I just edited my posts and stuff... (Habit of deleting posts when I previously double posted)
File I/O, nested loops, etc.
PostPosted: Wed Mar 11, 2009 2:51 pm
Well here's a new problem:
      int index = 0;
   double [] temps = new double[11];
   File fileName = new File("westpalmbeach.txt");
   Scanner inFile = new Scanner(fileName);
   while (inFile.hasNextDouble())
      temps[index] = inFile.nextDouble();
      index++;
   for(int n = 0; n <= index; n++)
         System.out.println("index position " + n + " " + temps[n]);
*sigh* Errors...
So what I have is a file and it has 11 doubles, all right? (westpb.text)
When i set my array to 11 it gives me an error with no chance for display but when I change it to 12 I get a display all the way down to index 11 but I get an error though :/
Assume any other code that you don't see works :P
Edit: Well I change it to 13 and I get display to a twelfth (but nonexistant double) Which output is not desired.
This is simplified code for the assignment I am doing to make it easier for me to debug.
PostPosted: Wed Mar 11, 2009 3:28 pm
Your problem is that array indices for an array of length n go from 0 to n - 1. You are going from 0 to n. Since temps[n] does not exist, you get an error.
PostPosted: Wed Mar 11, 2009 3:32 pm
Actually... I just figured it out.... It's one of the most simple and retarded mistakes I have ever made
for(int n = 0; n [b]<=[/b] index; n++)
The for stops AFTER n is = index.
My solution?
for(int n = 0; n [b]<[/b] index; n++)
Silly me D:
PostPosted: Wed Mar 11, 2009 4:01 pm
Don't worry...
it's not retarded at all. ArrayIndexOutOfBoundsException is one of the most common errors that everyone makes.
PostPosted: Thu Mar 12, 2009 4:01 am
Quertior wrote:
Don't worry...
No they don't! pffftt... ::looks away::
Uh... crap. :P
PostPosted: Thu Mar 12, 2009 10:44 am
CrashTECH wrote:
Quertior wrote:
Don't worry...
Uh... crap. :P
What makes it worse is that looking in what seems to be a perfectly fine for statement is one of the last places programmers look while debugging!
PostPosted: Thu Mar 12, 2009 3:09 pm
Yeah, no one likes to admit it, but they make small errors all the time. That's why Java started throwing exceptions for index out of bounds, unlike C and C++ which would just keep operating and your only clue would be when the value at the "final" index in the array was something like 145998!
PostPosted: Sat Mar 14, 2009 4:51 am
   Code Removed for grading purposes :D
Currently I will be debugging this.
I fixed that problem, now to use Printf properly to format the output.
___
Edit:
Done with that assignment code is no longer required. Printf & arrays.
PostPosted: Sun Mar 15, 2009 9:40 pm
eek!! printf() is a relic from C and C++. i still cant believe that there is no better way yet.
The March of Progress
1980: C
printf("%10.2f", x);
1988: C++
cout << setw(10) << setprecision(2) << showpoint << x;
1996: Java
java.text.NumberFormat formatter = java.text.NumberFormat.getNumberInstance();
formatter.setMinimumFractionDigits(2);
formatter.setMaximumFractionDigits(2); String s = formatter.format(x);
for (int i = s.length(); i < 10; i++) System.out.print(' ');
System.out.print(s);
2004: Java
System.out.printf("%10.2f", x);
2008: Scala and Groovy
printf("%10.2f", x)
PostPosted: Mon Mar 16, 2009 12:20 pm
I like the Scala and Groovy version the best. :P We also need IDEs which detect how often a person uses a certain command.
Try that on for size. Notice how there are no errors and I still get ArrayIndexOoB (figured out the problem, silly me)
      removed
PostPosted: Mon Mar 16, 2009 1:40 pm
note the lack of semicolon in scala and groovy. improvement!
and for sure, runtime exceptions are 20x harder to debug than compile time errors.
PostPosted: Mon Mar 16, 2009 5:38 pm
:P
removed
I feel so dirty.... Like something in my head just.. broke D:
