It is currently Sun Apr 26, 2015 12:54 am
 Post subject: Can any one please explain how a nested for loop works in c+
PostPosted: Fri Oct 31, 2008 6:28 pm
i looked at the book and searched google, but still i have no clue how it works. I know how one for loop works; it reads the initial value once, then it checks the condition, if its true it runs the statement block and it then runs the increment (if it has one).
PostPosted: Fri Oct 31, 2008 10:06 pm
Well, it's been a long time since I've dealt with C, but as you know, a For loop will run everything inside it at least once. If you want to do something multiple times for each of the For iterations, you use a nested For. It can be good for displaying or dealing with 2d and 3d tables of information (rows and columns).
The simplest way of showing this is a table of 5x5 squares. Each of those squares has a 2 position ID that represents the position it's in. First part of the ID represents the column. Second ID represents the row. Start off from 1, counting to 5 to the right. 1 counting to 5 to the bottom. So the first square is 1,1. The next to the right is 2, 1. The next down is 1,2. And so on.
Sort of like this:
1,1 - 2,1 - 3,1 - 4,1 - 5,1
1,2 - 2,2 - 3,2 - 4,2 - 5,2
1,3 - 2,3 - 3,3 - 4,3 - 5,3
1,4 - 2,4 - 3,4 - 4,4 - 5,4
1,5 - 2,5 - 3,5 - 4,5 - 5,5
Now, let's say you want to display every value in that table. You can do a printf for each cell in there (25 lines). Or you can use a 2 layer nested For loop (3 lines or so). Layer one goes through each row down. The second layer goes through each column across.
pseudo code
for i = 1 to 5, i++
for j = 1 to 5, j++
printf(i,j)
You can tweak the conditions to display different ways (say for example Even or Odd cells only, or in reverse, etc). But anytime you want to do a mass thing to a matrix table, a nested for can be handy.
This isn't the only thing it's useful for, but it's a good example.
PostPosted: Sat Nov 01, 2008 4:55 am
Team Member Top 1000
I'm in Computer Science 1 at my college, and didn't know you could write it the first way. What I mean is usually for the for loop, I'd write:
for(i=0, i <6, i++) etc.
Or do less than equals to 5.
AJ
PostPosted: Sat Nov 01, 2008 8:56 am
7yrs+11,000 Posts
7yrs+11,000 Posts
Nested loops work like normal ones.
for (i = 0; i < 10; i++)
   for (y = 0; y < 10; y++)
      cout << y << endl;
That particular code would print out the sequence 1-10 10 times.
When the condition of a loop is met, it executes all the code between it's inherit brackets (assuming you are not using an exit function) - this can be anything, including new loops.
When it reaches it reaches the end, it does the same thing over and over until the condition is false, thus the name "loop".
Edit: This may help you more than me: http://mathbits.com/mathbits/compsci/looping/nested.htm
PostPosted: Fri Nov 21, 2008 9:57 pm
      cout << y << endl;
Interesting ...... so basically the outer loop controls how many times the inner loop runs?
PostPosted: Sat Nov 22, 2008 7:21 am
Sort of.
Think of it like this. The inner loop will run to its LCV (loop control variable or value) value for each iteration of the outer loop.
   for (y = 0; y < 5; y++)
      cout << y << endl;
Modifying gamer's example to have different numbers:
So when the code first hits that line, you will get this:
i = 0, y = 0
i = 0, y = 1
i = 0, y = 2
i = 0, y = 3
i = 0, y = 4
i = 0, y = 5
Now, we go back to the outer loop and increment i.
i = 1, y = 0
i = 1, y = 1
i = 1, y = 2
i = 1, y = 3
i = 1, y = 4
i = 1, y = 5
And again... till i reaches 10.
PostPosted: Sun Nov 23, 2008 10:55 am
Wouldn't it stop at:
y=0
y=1
y=2
y=3
y=4
since it breaks at 5? Also, so that code would print out y = 1 through 5 ten times?
PostPosted: Sun Nov 23, 2008 4:20 pm
Okay, you have me. I was copy and paste happy. :)
PostPosted: Sun Nov 23, 2008 5:51 pm
but would it print out 1-5 ten times?
PostPosted: Sun Nov 23, 2008 8:08 pm
Yes.
Edit: Well, 0 through 4 as I wrote it.
PostPosted: Sat Nov 29, 2008 5:26 pm
Loops are indepentent of eachother. A loop will run until its condition is rendered false. This behavior is the same with nesting
for (int i = 0; i < 10; i++)
Console.WriteLine(i);
This runs 10 times
for (int j = 0; j < 10; j++)
The inner loop hasn't changed a bit, it will still run 10 times.
BUT when the loop is finished, the outer loop calls the innterloop again because IT needs to loop.
I hope this helps.
