It is currently Sat Apr 18, 2015 4:59 am
 Post subject: EXCEL/VB help needed
PostPosted: Thu Oct 23, 2008 9:18 am
Location: Folding as QQue - que'ing up #300 of pork and beef
Does anyone have experience in writing/editing Excel macros? I need to alter the absolute range references noted by "SS-*************************** " to allow for a variable number of records.
I am using Selection.End(xlDown).Select to use an existing column of data to find the last record, but the record macro function then used the absolute range (L3:L321 or A1:L321) in future steps.
Thanks
Sub TechData()
' TechData Macro
' Macro recorded 10/23/2008 by SS
' Keyboard Shortcut: Ctrl+q
' SS-Copy all original POS line item data to Sheet1
    Cells.Select
    Selection.Copy
    Sheets("Sheet1").Select
    Range("A1").Select
    ActiveSheet.Paste
' SS-Rename Sheet1 as Summary
    Sheets("Sheet1").Name = "Summary"
' SS-Delete unnecessary columns
    Columns("B:B").Select
    Application.CutCopyMode = False
    Selection.Delete Shift:=xlToLeft
    Columns("D:O").Select
' SS-Move product number column in front of product description
    Columns("D:D").Select
    Selection.Insert Shift:=xlToRight
    Columns("F:F").Select
    Selection.Cut
    ActiveSheet.Paste
' SS-Add NET column (ExtCOGS-ExtCOGR)
    Range("L1").Select
    Selection.Style = "Normal_Sheet1"
    Selection.Borders(xlDiagonalDown).LineStyle = xlNone
    Selection.Borders(xlDiagonalUp).LineStyle = xlNone
    With Selection.Borders(xlEdgeLeft)
        .LineStyle = xlContinuous
        .Weight = xlThin
        .ColorIndex = xlAutomatic
    End With
    Selection.Borders(xlEdgeTop).LineStyle = xlNone
    Selection.Borders(xlEdgeBottom).LineStyle = xlNone
    Selection.Borders(xlEdgeRight).LineStyle = xlNone
    Selection.Borders(xlInsideVertical).LineStyle = xlNone
    Selection.Borders(xlInsideHorizontal).LineStyle = xlNone
    With Selection
        .HorizontalAlignment = xlCenter
        .VerticalAlignment = xlBottom
        .WrapText = False
        .Orientation = 0
        .AddIndent = False
        .ShrinkToFit = False
        .ReadingOrder = xlContext
        .MergeCells = False
    End With
    Selection.NumberFormat = "$#,##0.00"
    ActiveCell.FormulaR1C1 = "Net"
    With ActiveCell.Characters(Start:=1, Length:=3).Font
        .Name = "Arial"
        .FontStyle = "Regular"
        .Size = 9
        .Strikethrough = False
        .Superscript = False
        .Subscript = False
        .OutlineFont = False
        .Shadow = False
        .Underline = xlUnderlineStyleNone
        .ColorIndex = 1
    End With
    Range("L2").Select
    ActiveCell.FormulaR1C1 = "=RC[-4]-RC[-1]"
    Range("K3").Select
    Range("L2").Select
    Selection.Copy
    Range("K2").Select
' SS-*************************** need to correct absolute range reference
    Range("L3:L321").Select
    Range("L321").Activate
    ActiveSheet.Paste
    Range("A1").Select
' SS-Sort data records
    Range("A1:L321").Sort Key1:=Range("C2"), Order1:=xlAscending, Header:= _
        xlGuess, OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom, _
        DataOption1:=xlSortNormal
' SS-Subtotal sorted data records break on customer name and sum on net
    Selection.Subtotal GroupBy:=3, Function:=xlSum, TotalList:=Array(12), _
        Replace:=True, PageBreaks:=False, SummaryBelowData:=True
End Sub
PostPosted: Thu Oct 23, 2008 1:10 pm
figured it out
