It is currently Thu Jan 29, 2015 1:37 am
 Post subject: Can anyone help me figure out this c++ bug?
PostPosted: Sun Oct 12, 2008 1:11 pm
These are the errors I am getting. I am new to c++ and just starting to use classes so I'm kinda lost.
Lab6.cpp(69) : error C2065: 'bank1' : undeclared identifier
.\Lab6.cpp(69) : error C2228: left of '.Withdraw' must have class/struct/union
type is ''unknown-type''
.\Lab6.cpp(74) : error C2065: 'bank1' : undeclared identifier
.\Lab6.cpp(74) : error C2228: left of '.GetBalance' must have class/struct/union
Code in Main
// Lab6.cpp : main project file.
#include "stdafx.h"
#include <string>
#include <iostream>
#include "BankAccount.h"
//using namespace System;
using namespace std;
int main()
    //Begin Main
   int k,m,n=1,ini_acc;
   double money,x,ini_bal;
   char choice;
//Main Welcome prompt
   cout<<"------------------------------------------------------------------\n\n";
   cout<<"Welcome to AUFederal\n\n";
//Loops the main program to allow multipe runs to be tested without needing to rerun.
while(n==1){
   k=1;
   while (k==1){
//This is for account one which uses the stack
//BankAccount bank1;
//BankAccount bank1 (ini_acc, ini_bal);  //account on the stack
   cout<<"\nPlease enter the account number you wish to access.\n\n";
   cin>>ini_acc; //set initial account number
   cout<<"\n\nPlease enter the your starting balance.\n\n";
   cin>>ini_bal;
   cout<<"\nPlease enter the amount you wish to deposit in account 1 $xxxx.xx\n\n";
   cin>>money;
   //read in deposit amount
   bank1.Deposit(money); //deposit tbe money
   cout<<"Do you wish to make another deposit? y/n \n";
   cin>>choice;
   //deposit again?
      if (choice == 'y'){
      k=1;
      else{
         k=0;
   cout<<"\nPlease enter the amount you wish to withdraw $xxx.xx\n\n";
   cin>>money;
   //how much to withdraw?
   x=bank1.Withdraw(money);
   cout<<"\nYou were able to withdraw: "<<x<<"\n\n";
   //get the balance
   x= bank1.GetBalance();
   cout<<"Your balance is: "<<x<<"\n\n";
//Now run for account which uses the heap
   BankAccount^ bank2 = gcnew BankAccount(ini_acc, ini_bal); //acount on the heap
   m=1;
   while (m==1){
   //repeat for account 2.
   cout<<"\nPlease enter the amount you wish to deposit in account 2 $xxxx.xx\n\n";
   cin>>money;
   bank2->Deposit(money);
   cin>>choice;
      if (choice == 'y'){
      m=1;
      else{
         m=0;
   cin>>money;
   x=bank2->Withdraw(money);
   x=bank2->GetBalance();
   cout<<"Do you wish to rerun the program? y/n \n";
   cin>>choice;
      if (choice == 'y'){
      n=1;
      else{
         n=0;
Code in header file
#include "stdafx.h"
ref class BankAccount
   private:
      double balance;
      int account_Number;
   public:
      BankAccount():balance(0.0),account_Number(0)
      BankAccount(int ini_account, double ini_balance)
         balance=ini_balance;
         account_Number=ini_account;
      void Deposit(double amt);
      double  GetBalance();
      double Withdraw(double amt);
      int Acc_Num();
Code in function cpp file
#include "stdafx.h"
void BankAccount::Deposit(double amt)
balance+= amt;
double BankAccount::GetBalance()
   return balance;
double BankAccount::Withdraw(double amt)
   double total;
   if(balance <= amt)
      total=balance;
      balance=0;
         return total;
   else
      total=amt;
      balance -= amt;
      return total;
int BankAccount::Acc_Num()
   return account_Number;
PostPosted: Mon Oct 13, 2008 8:00 am
Million Club - 5 Plus*
How did you create your C++ project? Was it a CLR project or a Win32 project?
"ref class" looks wrong -- try "class".
PostPosted: Mon Oct 13, 2008 8:08 am
Project is a CLR in visual studio.
ref class is supposed to make it run on the managed heap.
The first half of the program is supposed to run using the stack, the second half is supposed to run using the managed heap. Both are supposed to perform the exact same function.
If you comment out the first half of the code in main, the bottom half runs fine, but the first half will not compile.
PostPosted: Mon Oct 13, 2008 11:33 am
Far as I can see, bank1 is declared inside of while(k==1) block, which makes this block its scope.
Withdraw and GetBalance methods are both accessed outside the block, no longer within the name scope of bank1.
Either extend the inner while to end after GetBalance, or move bank1 declaration to the outside while.
EDIT - looking at 2nd half of code, moving bank1 declaration above "while(k==1)" is what you want to do.
