It is currently Sat Feb 28, 2015 7:45 pm
 Post subject: File Encryption / Decryption
PostPosted: Tue Oct 07, 2008 1:00 pm
Okay, so I am playing with this in preparation to really make some good use of the idea of encrypting/decrypting text files etc.
I did some googling on top of this, and it appears that people claim this does not work in .NET 2.0 (it does, I did it). However, I am not using DES I tried TripleDES (After finding out that AES isn't supported in 2.0 version of System.Security.Cryptography :( ) I do plan to find or implement AES later but it isn't necessary for proof of concept right now.
My issue is that the last character of my text file is missing from the final decryption. Does anybody have any ideas about this? Do you have a better method?
Also, something that isn't mission critical right now, can anybody suggest a change (or changes) that might make this work with more than just text files?
PostPosted: Tue Oct 07, 2008 2:46 pm
Million Club - 5 Plus*
http://msdn.microsoft.com/en-us/library ... ndael.aspx
Rijndael is AES with more block sizes (it was the submission name for AES). While it might not be exact, it should do the job close enough
Anyways, I've mainly played with hashes but I can try and look and see if I have any code that might help.
PostPosted: Tue Oct 07, 2008 4:53 pm
Any idea why I am losing the last character of the original text file after decryption?
PostPosted: Wed Oct 08, 2008 5:20 am
I found it, but I want to see if anybody else spots it in the article.
There is a funny point to mention, the bug is NOT in the code here, from the full code listing in the article. It is in a section in the article. This code doesn't have the bug:
using System;
using System.IO;
using System.Security;
using System.Security.Cryptography;
using System.Runtime.InteropServices;
using System.Text;
namespace CSEncryptDecrypt
   class Class1
      //  Call this function to remove the key from memory after use for security
      [System.Runtime.InteropServices.DllImport("KERNEL32.DLL", EntryPoint="RtlZeroMemory")]
      public static extern bool ZeroMemory(IntPtr Destination, int Length);
      // Function to Generate a 64 bits Key.
      static string GenerateKey()
         // Create an instance of Symetric Algorithm. Key and IV is generated automatically.
         DESCryptoServiceProvider desCrypto =(DESCryptoServiceProvider)DESCryptoServiceProvider.Create();
         // Use the Automatically generated key for Encryption.
         return ASCIIEncoding.ASCII.GetString(desCrypto.Key);
      static void EncryptFile(string sInputFilename,
         string sOutputFilename,
         string sKey)
         FileStream fsInput = new FileStream(sInputFilename,
            FileMode.Open,
            FileAccess.Read);
         FileStream fsEncrypted = new FileStream(sOutputFilename,
            FileMode.Create,
            FileAccess.Write);
         DESCryptoServiceProvider DES = new DESCryptoServiceProvider();
         DES.Key = ASCIIEncoding.ASCII.GetBytes(sKey);
         DES.IV = ASCIIEncoding.ASCII.GetBytes(sKey);
         ICryptoTransform desencrypt = DES.CreateEncryptor();
         CryptoStream cryptostream = new CryptoStream(fsEncrypted,
            desencrypt,
            CryptoStreamMode.Write);
         byte[] bytearrayinput = new byte[fsInput.Length];
         fsInput.Read(bytearrayinput, 0, bytearrayinput.Length);
         cryptostream.Write(bytearrayinput, 0, bytearrayinput.Length);
         cryptostream.Close();
         fsInput.Close();
         fsEncrypted.Close();
      static void DecryptFile(string sInputFilename,
         string sKey)
         //A 64 bit key and IV is required for this provider.
         //Set secret key For DES algorithm.
         //Set initialization vector.
         //Create a file stream to read the encrypted file back.
         FileStream fsread = new FileStream(sInputFilename,
            FileMode.Open,
            FileAccess.Read);
         //Create a DES decryptor from the DES instance.
         ICryptoTransform desdecrypt = DES.CreateDecryptor();
         //Create crypto stream set to read and do a
         //DES decryption transform on incoming bytes.
         CryptoStream cryptostreamDecr = new CryptoStream(fsread,
            desdecrypt,
            CryptoStreamMode.Read);
         //Print the contents of the decrypted file.
         StreamWriter fsDecrypted = new StreamWriter(sOutputFilename);
         fsDecrypted.Write(new StreamReader(cryptostreamDecr).ReadToEnd());
         fsDecrypted.Flush();
         fsDecrypted.Close();
      static void Main()
         // Must be 64 bits, 8 bytes.
         // Distribute this key to the user who will decrypt this file.
         string sSecretKey;
         // Get the Key for the file to Encrypt.
         sSecretKey = GenerateKey();
         // For additional security Pin the key.
         GCHandle gch = GCHandle.Alloc( sSecretKey,GCHandleType.Pinned );
         // Encrypt the file.
         EncryptFile(@"C:\MyData.txt",
            @"C:\Encrypted.txt",
            sSecretKey);
         // Decrypt the file.
         DecryptFile(@"C:\Encrypted.txt",
            @"C:\Decrypted.txt",
            sSecretKey);
         // Remove the Key from memory.
         ZeroMemory(gch.AddrOfPinnedObject(), sSecretKey.Length * 2);
         gch.Free();
PostPosted: Fri Oct 31, 2008 1:50 pm
Well, I've not done any .Net programming yet, but looking at the article, it's in the encryption part when they're reading the source file. Looks like they're setting the temporary array they're reading the file into to the file length - 1. Possibly due to thinking about starting from 0 vs 1. That sometimes gets me as well. Or thinking about excluding the EOF character (although that might be stripped automatically by the fsInput.Read).
PostPosted: Mon Nov 03, 2008 5:05 am
Winner!
Yeah, I read the article, and the little blocks where they describe the code was correctly Length-1 but the code at the end was wrong! Needless to say, I "saved time" by not re-writting and I just copied the full code.
Yeah, it didn't work. I was very WTF about it.
