It is currently Sun Mar 29, 2015 10:05 pm
 Post subject: Help with Lab
PostPosted: Mon Oct 06, 2008 7:09 am
Team Member Top 1000
Quote:
Assignment: for Comp Sci 1 C++
Write a function FillArray, which takes two arguments, the first is the name of a file, the second is an array of strings of size 500 with no data in it. Your function should open the file. The file will consist of strings each separated by whitespace.
Read the strings into the array until done. The return value should be the number of strings in the array. If for any reason hte function cannot open the file, it should return -1. THe function should close the file before it returns.
Use the song from Homework1 as your test data.
//Fill array
#include <iostream>
#include <string>
#include <fstream>
using namespace std;
int FillArray(string file, string large)
   int counter;
   ifstream song1;
   if (!song1.is_open)
      return -1;
   return 0;
int main ()
   string large(500);
   string file;
   int counter;
   cout << "Enter name of text file to open:" endl;
   cin >> file;
   counter = FillArray(file, large);
I have the file saved as song1. (it's the limerrick about the a queen...my professor is british.) So what should I do from here. I'm stuck
AJ
PostPosted: Mon Oct 06, 2008 7:29 am
What exactly are you stuck on?
PostPosted: Mon Oct 06, 2008 7:44 am
Never mind ... got it... I wasn't sure where to proceed.. My friend helped me.
//Fill array
#include <iostream>
#include <string>
#include <fstream>
int FillArray(string file, string large[500])
   int counter;
   counter = 0;
   ifstream song1;
   song1.open(file.c_str());
   if (!song1.is_open())
      return -1;
   while (!song1.eof())
      song1 >> large[counter];
      counter++;
   return counter -1 ;
int main ()
   string large[500];
   string file;
   int counter;
   cout << "Enter name of text file to open:" << endl;
   cin >> file;
   cout << counter << endl;
   return 0;
Thanks anyways.
AJ
PostPosted: Mon Oct 06, 2008 9:42 am
For the record and your future reference: we do not do homework here.
We will answer specific questions, but only if it is evident that doing so will not ruin the point of the homework exercise.
I am thinking we need to make a sticky.
PostPosted: Mon Oct 06, 2008 10:47 am
Good call.
Need HW Help? Look here first.
Have the rules in the first post and let homework discussions happen inside that thread. Lock them outside. Should be simple enough.
