It is currently Sat Apr 25, 2015 11:50 am
 Post subject: Need help with my home work
PostPosted: Tue Sep 30, 2008 7:05 pm
This is what i have to do:
Assignment 2 Cellular Phone Bill
Write a program that calculates and prints the bill for a cellular telephone company. The company offers two types of services: regular and premium. Its rates vary depending on the type of service. The rates are as follows:
Regular service: $10.00 plus first 50 minutes are free. Charges for over 50 minutes are $.20 pre minutes.
Premium service: $25.00 plus:
1. for calls made from 6:00am to 6:00pm, the first 75 minutes are free; charges for over 75 minutes are $.10 per minutes
2. for calls made from 6:00pm to 6:00am, the first 100 minutes are free; charges for over 100 minutes are $0.05 per minutes.
you program should prompt the user to enter an account number, a service code (type char), and the number of minutes of the service was used. A service code of r or R means regular service; a service code p or P means premium service. Treat any other character as error. Your program should output the account number, type of service, number of minutes the telephone service was used, and the amount due from the user.
For premium service, the customer may be using the service during the day and the night. Therefore, to calculate the bill, you must ask the user to input the number of minutes the service was used during the day and the number of minutes the service was used during the night.
The output should be nicely formatted. The amount due should be output with a '$' sign before the number and the number should be displayed with two digits after decimal point. ( for example, $45.50)
Now this is my code:
#include <iostream>
#include <iomanip>
using namespace std;
int account_number;
float minutes;
char service;
float amount_due;
float day_min;
float night_min;
float regular();
float premium();
int main()
   cout<< "Please enter your account number: " ;
   cin >> account_number;
   cout<< "Do you have Regular service or Premium service (r or p)? ";
    cin.ignore(0,'\n') >> service;
   cout<< service;
   if (service == 'r' || 'R')
      regular();
   else if (service == 'p' || 'P')
      premium();
   else
      cout<< "Wrong input, program terminated!" << endl;
      return 1;
float premium()
         cout<< "How many minutes were used during the day? ";
          cin >> day_min;
          cout<< "How many minutes were used during the night? ";
          cin >>night_min;
   if (day_min <= 75)
      amount_due = 25.00;
      cout<< fixed << showpoint << setprecision(2);
      cout<< "Amount due: $" << amount_due << endl;
      cout<< "Account number: "<< account_number <<endl;
      cout<< "Service type: "<< service << endl;
      cout<< "Minutes used: "<< day_min <<endl;
   else if (day_min > 75)
      amount_due = ((day_min - 75) * .10)+ 25.00;
   else if (night_min <= 100)
      amount_due = 25.00;
   else if (night_min > 100)
      amount_due = ((day_min - 100) * .05)+ 25.00;
   return 0;
float regular ()
   cout<< "How many minutes were used? ";
   cin >> minutes;
   if (minutes <= 50.00)
       amount_due = 10.00;
      cout<< "Minutes used: "<< minutes <<endl;
   else
       amount_due = ((minutes -50.00) * 0.20);
      cout<< setw(2) << showpoint << setprecision(3)<< "Amount due: $"<< amount_due << endl;
   return 0;
I want my program to terminate when someone types in a letter other than r, R, p, P. I am having trouble doing that any help please.
PostPosted: Wed Oct 01, 2008 3:06 am
Monkey Federation (Top 10)*
If you really want to simplify this part:
      regular();
      premium();
   else
      return 1;
Use a switch/case block. When you look at the syntax you will see where you can place the errors for invalid characters. I am assuming this is a 100 level c++ course? That would assume you have not been introduced to objects yet?
PostPosted: Wed Oct 01, 2008 7:26 am
we havent learn switch/case block. Can you spot anything wrong with my code?
PostPosted: Wed Oct 01, 2008 7:45 am
Your if statement I highlighted has issues. You have a syntax issue that is preventing the program from doing what you think it should.
This is homework so no one is going to give you the answer; only point you in the right direction.
PostPosted: Wed Oct 01, 2008 8:53 am
Look into toupper and tolower statements. Using one or the other of these will help you fix your IF block.
PostPosted: Wed Oct 01, 2008 9:21 am
i cant use those toupper and tolower functions; i havent learn that
PostPosted: Wed Oct 01, 2008 9:57 am
yay i got it. It should be
if (service == 'r' || service == 'R')
PostPosted: Wed Oct 01, 2008 10:27 am
ding ding ding!
PostPosted: Wed Oct 01, 2008 3:46 pm
If your teacher is going to penalize you for figuring out a better and more elegant solution, then they are a tool bag.
PostPosted: Wed Oct 01, 2008 3:53 pm
I agree.
PostPosted: Wed Oct 01, 2008 5:40 pm
but he did not figure it out, you told him about it. :P
Using a switch/case statement would look like this
switch(service)
   case 'p':
   case 'P': call_function_here();
            break;
  default: call_some_error_message();
This way since there is no break after the first case it falls to the next one. So if either an upper or lower is entered they both end up executing the same code.
Or, as Crash suggested, you could have modified the if statement to read
if(tolower(service) == 'p')
etc
etc...
