It is currently Mon Mar 30, 2015 8:49 am
 Post subject: GlobalMemoryStatusEx
PostPosted: Thu Sep 25, 2008 7:18 pm
I'd rather be modding!
Ok,
So why does this work:
from ctypes import *
from ctypes.wintypes import *
from sys import *
class MEMORYSTATUS(Structure):
    _fields_ = [
        ('dwLength', DWORD),
        ('dwMemoryLoad', DWORD),
        ('dwTotalPhys', DWORD),
        ('dwAvailPhys', DWORD),
        ('dwTotalPageFile', DWORD),
        ('dwAvailPageFile', DWORD),
        ('dwTotalVirtual', DWORD),
        ('dwAvailVirtual', DWORD),
def winmem():
    x = MEMORYSTATUS()
    windll.kernel32.GlobalMemoryStatus(byref(x))
    return x
m=winmem()
load = m.dwMemoryLoad
vram = m.dwAvailVirtual
vtot = m.dwTotalVirtual
pageav = m.dwAvailPageFile
pagetot = m.dwTotalPageFile
ramtot = m.dwTotalPhys
ramav = m.dwAvailPhys
bit = m.dwLength
print bit,vram,vtot,ramtot
But this doesn't:
from sys import *
class MEMORYSTATUSEX(Structure):
    _fields_ = [
        ('ullTotalPhys', ULONG),
        ('ullAvailPhys', ULONG),
        ('ullTotalPageFile', ULONG),
        ('ullAvailPageFile', ULONG),
        ('ullTotalVirtual', ULONG),
        ('ullAvailVirtual', ULONG),
def winmem():
    x = MEMORYSTATUSEX()
    windll.kernel32.GlobalMemoryStatusEx(byref(x))
    return x
m=winmem()
vram = m.ullAvailVirtual
vtot = m.ullTotalVirtual
pageav = m.ullAvailPageFile
pagetot = m.ullTotalPageFile
ramtot = m.ullTotalPhys
ramav = m.ullAvailPhys
bit = m.dwLength
The EX version is the new one and replaces the other.
When I say it doesn't work, I mean the first one reports the proper memory (within it's limits), but the second only reports zero's for everything
Any ideas?
PostPosted: Sat Sep 27, 2008 11:41 am
Team Member Top 100
Team Member Top 100
Look at the MSDN page: http://msdn.microsoft.com/en-us/library/aa366589(VS.85).aspx
Also, pay really close attention to the types used in the structure (DWORDLONG means 'unsigned __int64' or 'unsigned long long', i.e. an unsigned 64-bit int)
Also, you should call GetLastError() and see what the error was
