It is currently Sat Apr 18, 2015 6:11 am
 Post subject: Thread based Error / Event Logging
PostPosted: Thu Sep 25, 2008 9:46 am
Okay, I have NO idea if this is possible (or a good idea) but I am getting REALLY annoyed...
So I wrote this error logging class, to specs. It takes 3 objects as parameters, one for the exception, one for System.Relefection.MethodBase.GetCurrentMethod(), and one for a Sql Data object (Data Adapter, Table Adapter, or SQL Command)... spawns a thread, saves info to a DB or dumps a strongly typed dataset to xml...
no worries.
BUT
try
     ///Do Stuff....
catch (Exception Ex)
     ErrorLogging.LogError(Ex, System.Reflection.MethodBase.GetCurrentMethod(), null);
This is a PITA, not to mention, difficult to change if something should change somewhere.
Is it possible to have some object watching a thread, suck in the relevant information (using Reflection, similar to how I am doing it now) and spawn a child/worker thread to do this? Then it just happens no matter where the exception is?
This would be a life saver (as well as helping migrate other apps to use this type of error logging). I would like to use it to prevent the app from job closing too if possible. If it traps an error, it should try to gracefully quit what it was doing and move on (button click, throws an error, it just discards what it was doing and ends the event)?
PostPosted: Thu Sep 25, 2008 9:59 am
Million Club - 5 Plus*
Maybe the techniques here could help: http://www.codeproject.com/KB/exception ... dling.aspx
The other option would be to set up a delegate and use thread.start() on it.
PostPosted: Thu Sep 25, 2008 10:16 am
Okay... I will have to read up on that method. I know very little about delegates.
