It is currently Wed Apr 01, 2015 2:41 am
 Post subject: Java Build failure
PostPosted: Thu Sep 18, 2008 2:39 pm
Team Member Top 1000
Hi, i'm in like my 3rd wek of my AP computer science class and this is a project we finished about a week ago, but I decided to overachieve and am having a problem compiling.
* Spring.java
* Created on September 15, 2008, 10:24 AM
* To change this template, choose Tools | Template Manager
* and open the template in the editor.
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import java.util.*;
* @author teacher
public class Spring extends JApplet
        implements ActionListener
    public void init()
        JButton button = new JButton("Spring");
        button.addActionListener(this);
        Container c = getContentPane();
        c.setBackground(Color.green);
        c.add(button, BorderLayout.SOUTH);
    public void actionPerformed(ActionEvent e)
        Random r = new Random();
        Color randColor = new Color(r.nextInt(256), r.nextInt(256), r.nextInt(256));
        c.setBackground(randColor);
the last line is where it's failing. Also, I;m using both netbeans 5 (at school) and netbeans 6.1 (at home) as an IDE.
PostPosted: Thu Sep 25, 2008 11:36 am
You didn't say what the compiler error was specifically, but I'm betting it will say something like "undefined variable c".
In general methods can only access variables that are either passed to them as a parameter, declared in that method, or are global to the class. If we look closely at your code for your actionPerformed method we find that the variable c doesn't satisfy any of these conditions, and hence we cannot perform any actions on it.
c is declared in your init method which means that it can only be used within that method (init). This is why you get an error when you try to use it in the actionPerformed method. For further reading on Scope see this page http://en.wikiversity.org/wiki/Introduction_to_Programming/Scope or google OOP/programming scope.
More to the point, to fix your error we need a way to access c in actionPerformed. One solution to this problem is to give c global scope using the following code
* Spring.java
import java.awt.*;
import java.util.*;
* @author teacher
   //By declaring c here (in global scope) all methods within this class can
  //access the c variable
   Container c;
    public void init()
        //We still want to initialize c here, but it's already been declared so we
       //can remove the "Container" from this line
The only caveat I can see with this code is that you must make sure that your init method is called before the actionPerformed method. If it's not then you'll probably get a null-pointer exception at runtime because c won't have been initialized before you try to use it.
I hope this helps.
Gox
PostPosted: Thu Sep 25, 2008 1:15 pm
thanks, I'm honoured to have your first post. but I semi fixed the problem and by now I figure I may as well pay attention in class instead of dealing with a 50 line program.
