It is currently Fri Mar 27, 2015 3:15 am
 Post subject: Want to learn java and python
PostPosted: Wed Aug 27, 2008 11:28 am
Well let me say first that i have absolutly no experience at programming whatsoever :D So just to put that out there. I really want to learn Java first then once i get that ill try python then maybe VB. But yeah whats the best way to start learning java and what can i do with it once i learn how to use it. Oh and would it be better to learn it on linux or windows? Thnx :D :D :D
PostPosted: Wed Aug 27, 2008 11:43 am
http://www.maximumpc.com/forums/viewtopic.php?t=23833
Work in whichever OS you feel most comfortable. Learning a new OS while trying to learn to program will be distracting.
PostPosted: Fri Aug 29, 2008 5:54 pm
Bitchin' Fast 3D Z8000*
For people planning on getting started with Java, I would highly recommend using NetBeans (not that Eclipse isn't any good, but it does require more configuration that you'll probably find very confusing).
Tutorials abound... I would start with the first cup of Java tutorial on Sun's site.
PostPosted: Sat Aug 30, 2008 10:43 pm
What is the purpose of python and java?
PostPosted: Sun Aug 31, 2008 4:56 am
They are programming languages.
PostPosted: Sun Aug 31, 2008 5:52 pm
oh........really. :shock: I know but what type of applications do they create. :?:
PostPosted: Sun Aug 31, 2008 7:34 pm
Million Club - 5 Plus*
Any type of program that the programmer chooses to make
PostPosted: Sun Aug 31, 2008 9:32 pm
Ok this thread http://www.maximumpc.com/forums/viewtopic.php?t=23833
Is great and all but where is a simple java, IM A NOOB AND HAVE NO CLUE WHAT IM DOING TUTORIAL? Thanks :D
PostPosted: Mon Sep 01, 2008 10:34 am
Read the second page of the thread you just posted. The first post asks your question and the next two answer it.
I'll need to clean that threat up a little bit .. it does go off-topic a bit.
PostPosted: Mon Sep 01, 2008 10:31 pm
Here...
http://java.sun.com/docs/books/tutorial ... d/TOC.html
http://www.netbeans.org/kb/trails/java-se.html
Both Python and Java are Turing-complete languages, therefore, anything that can be computed on a Universal Turing Machine, which your computer is equivalent to, can in theory be done with either language. In practice, some things will be a bit easier in Java others in Python.
Do you have a paticular project in mind?
PostPosted: Wed Sep 03, 2008 5:28 am
Thanks. 8)
PostPosted: Wed Sep 03, 2008 7:29 am
This is a good question, as sometimes it dictates which language / platform / framework is better suited for that task.
PostPosted: Wed Sep 03, 2008 9:44 pm
True -- but a beginner choosing between Python and Java is going to have a difficult time making a bad choice though. =)
Have you seen the thread on formatting output? Kybo may be a bit crazy. :)
PostPosted: Wed Sep 03, 2008 11:37 pm
Team Member Top 100
Team Member Top 100
I'm not crazy, just an insomniac
PostPosted: Thu Sep 04, 2008 4:59 am
True, but most high level languages are a good choice for just about anything. I really think it comes down to targeted platform and programmer preference.
PostPosted: Sat Sep 06, 2008 9:26 am
If you've never programmed before, I recommend you check out Game Maker first. It'll teach you the basic concepts behind the logic of programs with a drag'n'drop interface, and once you're ready, you can use its built-in programming language. IMO, it's the greatest learning experience you'll ever get from a programming environment.
PostPosted: Sun Mar 15, 2009 12:19 am
Ok i got a project i Want to do. Is there any way i can use java to make widgets on my desktop for my own personal use?
PostPosted: Sun Mar 15, 2009 5:11 am
You're diving in very deep very fast.
Read my starting out thread @ http://www.maximumpc.com/forums/viewtop ... 19&start=0
Then google around for the terms I'm using.
