It is currently Mon Apr 27, 2015 10:20 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jul 30, 2008 5:02 pm
Million Club - 5 Plus*
hbgrg wrote:
Here it is:
void hexadecimal(int number)
   stack hex;
   int remainder;
   while (number > 0)
      remainder = number % 16;
      number = number/16;
      if (remainder > 9)
         hex.push('A'  + remainder - 10);
      else
         hex.push(remainder);
      hex.pop();
Ah, DOH! Why did I miss this one earlier?
casting an int to a char starts it at ASCII \0, or NULL. Adding '0' to the else remainder works
else {
    hex.push('0' + remainder);
BTW, isEmpty is broke with an assignment in the if statement (single equals should be double)
PostPosted: Wed Jul 30, 2008 5:08 pm
hahah YAYYY i actually fixed everything (including the isEmpty) before I saw this post :D:D:D:D I'm finally doneee
Thanks EVERYONE who helped!!
PostPosted: Wed Jul 30, 2008 6:01 pm
Great work! :)
Now, if you really want to learn .. step back and tell us what you'd do differently if you had to start the project again from scratch.
PostPosted: Wed Jul 30, 2008 9:28 pm
ummm I'd prolly connect all three functions in a way because they are very similar (use modulus and divide operators)... And I'd use the stack class for octal too... :) that sound good?
PostPosted: Thu Jul 31, 2008 6:50 am
Yep. :)
In each of the conversion functions, you did the same thing. You just did it with different bases. So, instead of having binary(int), hex(int) and octal(int), you could have a function called convert that takes a starting base, an end base and a number and converts accordingly.
int convert(int baseStart, int baseEnd, int number)
Of course, if you want to make this possible with return base greater than 10, you would need a return type that includes characters. A character string or an array, for instance. ;)
Also, you could definitely use the stack for each of the functions in your original code or in the 'new' code.
This makes your code reusable because it can convert from any base to any other. It also makes it easier to read, easier to maintain and it looks nicer. It is not necessarily more efficient, though. I won't get into efficiency here, but I will point out that efficiency has nothing to do with the number of lines of code you have in your source .. a common misconception among programmers until they get bitchslapped by the higher maths and learn algorithmic proofs of efficiency and correctness. That is for another day.
Damn it, I should be working here. ;) Hope we've helped. Feel free to post your next assignment so we can help you think it through. I think we did a good job of leading you without handing you the answers or losing you along the way. Yes?
PostPosted: Thu Jul 31, 2008 9:10 pm
Yes thank you all!!! I learned a lot from you guys...
(Not so) sadly, my class is over so I dont think I'll be coming back with anymore assignments but I think I'm going to take flash sometime so I might comeback with questions about that :D
