It is currently Mon Jan 26, 2015 3:52 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Jul 29, 2008 12:30 pm
So would this be proper pop and push functions for the class?
class stack
public:
   void push(char i)
      char * stackChar = new char[100];
      int stackSize = 0;
      stackChar[stackSize++] = i;
   int pop()
      int stackSize = 0;
      return stackChar[--stackSize];
How would I check if the stack was empty and how would I impliment it into my hexadecimal function:
void hexadecimal(int number)
   stack hex;
   int remainder;
   while (number > 0)
      remainder = number % 16;
      number = number/16;
      if (remainder > 9)
         hex.push('A'  + remainder - 10) ;
      else hex.push(remainder);
PostPosted: Tue Jul 29, 2008 12:41 pm
Monkey Federation (Top 10)*
The stack class is already implemented as part of the STL.
Here is a quick and dirty on stacks http://www.cppreference.com/cppstack/index.html
PostPosted: Tue Jul 29, 2008 2:14 pm
Million Club - 5 Plus*
It's really close. Store the array and the number of elements in the stack in private class level variables.
That will also get you isEmpty()
@Lodis4: The exercise here is to not use the STL for the stacks. Anyways, doing it by hand is always good to know (at least the first time, then the STL should be used)
PostPosted: Tue Jul 29, 2008 2:25 pm
Ok how do I know how many times to pop?
EDIT:
#include <iostream>
using namespace std;
class stack
public:
   void push(char i)
      int stackSize = 0;
   int pop()
      int stackSize = 0;
   bool isEmpty()
      if (stackSize = 0)
         bool empty = true;
   void showSize ()
      cout << stackSize;
private:
   char stackChar[100];
   int stackSize;
void binary(int number)
   int remainder;
   if(number <= 1)
      cout << number;
      return;
   remainder = number%2;
   binary(number >> 1);
   cout << remainder;
   stack hex;
   int remainder;
   while (number > 0)
      number = number/16;
      if (remainder > 9)
void octal(int number)
   int remainder;
   int i;
   int ten = 10;
   remainder = number % 8;
   number = number/8;
   i = remainder;
   while (number >= 1)
      remainder = number%8;
      number = number/8;
      i += remainder * ten;
      ten = ten * 10;
   cout << i << "\n";
int main ()
   int number;
   cout << "Enter a number in decimal: ";
   cin >> number;
   int spec;
   cout << "Specify whether you want to convert to Binary, Octal, or Hexadecimal (1-3): ";
   cin >> spec;
   if (spec == 1)
      binary (number);
      cout << "\n";
   if (spec == 2)
      octal (number);
   if (spec == 3)
      hexadecimal (number);
   return 0;
There is my entire code did I make the stack class right? How do I implement the popping?
PostPosted: Tue Jul 29, 2008 4:38 pm
You only ever pop once per function call, just like you implemented it. Add a check to see if its empty first and it should work like a charm.
This is wrong (for a very obvious reason and one not as obvious reason ;) )
bool isEmpty()
      if (stackSize = 0)
         bool empty = true;
PostPosted: Tue Jul 29, 2008 5:34 pm
hbgrg wrote:
#include <iostream>
void push(char i)
   int stackSize = 0;
int pop()
   int stackSize = 0;
These two are wrong also (for the same exact reason).
PostPosted: Tue Jul 29, 2008 5:43 pm
I hate to be retarded (I can't help it in c++) but what would that reason be? It all looks right to me exept for maybe the bool cuz I didn't really know what to do on that one...
PostPosted: Tue Jul 29, 2008 6:09 pm
stackSize is being redefined as a locally scoped variable in those.
Assignment in the if statement (and locally scoped variable with no return value)
PostPosted: Tue Jul 29, 2008 6:44 pm
I understand what you mean because if theyre local they're deleted and can't be used in other places right? But how do I set stackSize to 0 without redefining it as a local variable?
PostPosted: Tue Jul 29, 2008 8:15 pm
stackSize is a class variable, initialize it in the constructor of the class and assume it's ready when you go into the function.
(you don't want to say you have an empty stack and then remove one from it anyways)
PostPosted: Tue Jul 29, 2008 9:18 pm
What am I doing wrong :cry: :cry: :cry:
#include <iostream>
class stack
public:
   stack ();
   ~stack() {}
   void push(char i)
   int pop()
   bool isEmpty()
      if (stackSize = 0)
         empty = true;
      else
         empty = false;
      return empty;
private:
   int stackSize;
   bool empty;
stack::stack()
   stackSize = 0;
I get no result when I push and then pop :cry:
PostPosted: Wed Jul 30, 2008 10:25 am
hbgrg wrote:
        int pop()
   bool isEmpty()
      if (stackSize = 0)
         empty = true;
      else
         empty = false;
      return empty;
In your pop() method, return type does not match the type of the array.
In you isEmpty() method, you still have an assignment in your if statement.
PostPosted: Wed Jul 30, 2008 11:18 am
How would I check if the stack is empty without using an if statement? Should I use some other kind of statement like for or while or something? and the push and pop still dont work :[
Stack Class:
class stack
public:
   stack ();
   ~stack() {}
   void push(char i)
   char pop()
   bool isEmpty()
      if (stackSize != 0)
         empty = false;
      else
         empty = true;
      return empty;
private:
   int stackSize;
   bool empty;
Hexadecimal Converter Function:
   stack hex;
   int remainder;
   while (number > 0)
      number = number/16;
      if (remainder > 9)
   hex.pop();
Help? I need to turn this in tonight :[[[[
PostPosted: Wed Jul 30, 2008 12:05 pm
He didn't say that you can't do it with an if-statement (you need one, actually). He said that you don't need an assignment statement. You don't need the 'empty' variable at all.
What is wrong with the rest of your code? I'm not compiling it ... you need to figure most of this out yourself, so if you can't decipher the compilation errors, post those and we can help you figure out what the problem is.
Learning to debug is almost as important as learning not to make bugs in the first place. :)
PostPosted: Wed Jul 30, 2008 12:45 pm
I'd be fine with debugging hahaha... But theres no errors o__O it just doesn't display anything when I enter an integer and try to convert it to hexadecimal :(
PostPosted: Wed Jul 30, 2008 1:35 pm
Im getting kinda desperate now as this assignment is due in like a few hours o__O
class stack
public:
   stack () {stackSize = 0;};
   ~stack() {}
   void push(char i)
   void pop()
      while (stackSize > 0)
         cout << stackChar[--stackSize];
   bool isEmpty ()
      if (stackSize = 0)
         return true;
      else
         return false;
so I changed it up a bit... Now when I entered the number 3345 it gave me "D :) :)" whats up with that? PLEASE HELP?!?!
PostPosted: Wed Jul 30, 2008 2:48 pm
here is a math forum explaining how to solve math problems with c++
http://mathforum.org/library/drmath/view/54347.html
PostPosted: Wed Jul 30, 2008 3:07 pm
Thats very helpful but I am doing this for a class and have specific requirments for what I have to do... My class starts in an hour o__O and todays the last day to turn in assignments... can someone help me? I think im getting the letters part fine but when it comes to numbers it usually couts smiley faces... Why is it doing that?
PostPosted: Wed Jul 30, 2008 3:58 pm
Even if its too late, post the entire source code so we can run it and see what's going on
PostPosted: Wed Jul 30, 2008 4:45 pm
Here it is:
#include <iostream>
class stack
public:
   ~stack() {}
   void push(char i)
   void pop()
   bool isEmpty ()
      if (stackSize = 0)
         return true;
      else
         return false;
private:
   int stackSize;
   int remainder;
   if(number <= 1)
      cout << number;
      return;
   cout << remainder;
   stack hex;
   int remainder;
   while (number > 0)
      number = number/16;
      if (remainder > 9)
         hex.push('A'  + remainder - 10);
      else
      hex.pop();
   int remainder;
   int i;
   int ten = 10;
   number = number/8;
   i = remainder;
   while (number >= 1)
      number = number/8;
      ten = ten * 10;
   cout << i << "\n";
int main ()
   int number;
   cin >> number;
   int spec;
   cin >> spec;
   if (spec == 1)
      binary (number);
      cout << "\n";
   if (spec == 2)
      octal (number);
   if (spec == 3)
   return 0;
Thanks for any help,
Greg
