It is currently Sun Mar 01, 2015 8:09 am
 Post subject: Just a little project VB.NET
PostPosted: Thu Jun 19, 2008 9:57 am
I have been trying to find a way to move the mouse using VB.NET programming, I have succeded, It took a while, but I finally found how to do it. Now the problem lies in how to get the color of a pixel anywhere on the screen when the x y coords are specified. I can't seem to find it anywhere. I use Visual Studio 2008. "Getpixel." command does not seem to exist in it. Here is my current code.
Public Class Form1
    Private Structure POINTAPI
        Dim x As Long
        Dim y As Long
    End Structure
    Private Declare Function ClientToScreen Lib "user32" _
    (ByVal hwnd As Long, ByVal lpPoint As POINTAPI) As Long
    Private Declare Function SetCursorPos Lib "user32" _
    (ByVal x As Long, ByVal y As Long) As Long
    Public Function SetCursorPosition(ByVal Window As Object, ByVal xPos As _
Long, ByVal yPos As Long) As Boolean
        On Error GoTo errorhandler
        Dim x As Long, y As Long
        Dim lRet As Long
        Dim lHandle As Long
        Dim typPoint As POINTAPI
        lHandle = Window.hwnd
        x = CLng(xPos / 15)
        y = CLng(yPos / 15)
        typPoint.x = x
        typPoint.y = y
        lRet = ClientToScreen(lHandle, typPoint)
        lRet = SetCursorPos(typPoint.x, typPoint.y)
        SetCursorPosition = (lRet <> 0)
        Exit Function
errorhandler:
        SetCursorPosition = False
        Exit Function
    End Function
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        SetCursorPos(txtX.Text, txtY.Text)
        lblCurrentPs.Text = ("X = " & MousePosition.X & " And Y = " & MousePosition.Y)
    End Sub
End Class
 Post subject: Color under mouse
PostPosted: Wed Jun 25, 2008 6:52 pm
Check out the code here, you should be able to figure it out.
http://www.codeguru.com/vb/gen/vb_graphics/article.php/c2357/
Good luck,
