It is currently Mon Mar 02, 2015 1:30 pm
 Post subject: C++ array/pointer question
PostPosted: Tue Dec 14, 2004 6:53 pm
It's been a while since I have used C++. Today I decided to brush up on it and made a smiple calculation program with an array. However when i go to display the info from the array i get only addresslocations not the actual value in the position. here is the code remember i said it was simple just for my minds value.
#include "stdafx.h"
main(void)
   int nums[101];
   double userinput;
   double output[101];
   int cnt;
   char hold;
   for (cnt =0; cnt <= 99; cnt++);
      nums [cnt] = nums[cnt] + 1;
   std::cout << "Please enter any number" << std::endl;
   std::cin >> userinput;
   for (cnt = 0; cnt <=99; cnt++)
      double test;
      output[cnt] = nums[cnt] * userinput;
      test -> output[cnt];
      std::cout << "The value for spot " << cnt << " is" << test << std::endl;
   std::cout << "Halting the program for information" << std::endl;
   std::cin >> hold;
      return 0;
PostPosted: Tue Dec 14, 2004 7:40 pm
Team Member Top 100
Team Member Top 100
Try *test.
PostPosted: Tue Dec 14, 2004 7:53 pm
i get compiler error illegal indirection
PostPosted: Tue Dec 14, 2004 9:00 pm
Team Member Top 100
Team Member Top 100
And I get "error C2227: left of '->output' must point to class/struct/union".
Why not just use an assignment? test = output[cnt];
PostPosted: Tue Dec 14, 2004 10:23 pm
ya i did have it as = i forgot to change it back after testing before putting it up here.
 Post subject: Re: C++ array/pointer question
PostPosted: Wed Dec 15, 2004 11:35 am
Your problem is that you have a semi-colon after your for-statement.
Remove it.
All better.
#include <iostream>
using namespace std;
int main(void) {
    int nums[101];
    double userinput;
    double output[101];
    int cnt;
    char hold;
    cout << "Please enter any number" << endl;
    cin >> userinput;
    for (cnt = 0; cnt <=99; cnt++) {
        double test;
        test = output[cnt];
        cout << "The value for spot " << cnt << " is" << test << endl;
    cout << "Halting the program for information" << endl;
    cin >> hold;
    return 0;
PostPosted: Wed Dec 15, 2004 12:07 pm
that wasnt the problem. I acutally put that in later to as a test heres the code as it is now
#include "stdafx.h"
main(void)
   int nums[101];
   double userinput;
   double output[101];
   int cnt;
   char hold;
      double test;
      test = output[cnt];
   std::cin >> hold;
      return 0;
and this what i get onscreen when i run it i'll start at 98 to make it easer for me
The value for spot 98 is -2.57698e+009
The Value for spot 99 is -2.57698e+009
I know that that is * 10^-9 and this is when i enter 3 as the value its giving me the memory address isnt it.
PostPosted: Wed Dec 15, 2004 12:24 pm
Remove it.
All better.
It is a one line for-loop ... a semi-colon is appropriate.
PostPosted: Wed Dec 15, 2004 1:50 pm
ahh convention discussion still no answer though.
PostPosted: Wed Dec 15, 2004 2:46 pm
Team Member Top 100
Team Member Top 100
No, it's not giving a memory address.
Your problem is that you don't initialize the values. Try this:
int main(void)
   int nums[100]={0};//no need for 101...
   //you must initialize it to a value if you want to use it like this
   double userinput;
   double output[100];
   int cnt;
   char hold;
   for (cnt =0; cnt <= 99; ++cnt)
      nums[cnt] += cnt;
   std::cin.ignore(1000,'\n');//ignore the newline
   for (cnt = 0; cnt <=99; ++cnt)
      std::cout << "The value for spot " << cnt << " is " << output[cnt] << std::endl;
   std::cin.get();
      return 0;
PostPosted: Wed Dec 15, 2004 4:11 pm
I understand now thankyou verymuch kybo for the help. I've spent the semester in VB so it didnt even occur to me to intialize the values.
PostPosted: Wed Dec 15, 2004 4:24 pm
Team Member Top 100
Team Member Top 100
Sure.
PostPosted: Wed Dec 15, 2004 7:34 pm
Jipstyle wrote:
Remove it.
All better.
You're correct. I had to do some reformatting when I tried to compile it under Borland and forgot about that syntax.
PostPosted: Thu Dec 16, 2004 8:29 am
Phalanx wrote:
Jipstyle wrote:
Remove it.
All better.
You're correct.
<Homer> Woooohooo!!! </Homer>
<Marge> Enjoy it, Homie ... you know I'll be right next time. </Marge>
<Homer> D'oh! </Homer>
:D
PostPosted: Thu Dec 23, 2004 2:39 pm
Bitchin' Fast 3D Z8000*
Jipstyle wrote:
Remove it.
All better.
Someone needs to kick you in the butt. :)
PostPosted: Thu Dec 23, 2004 2:44 pm
Nothing like a review to work out the kinks, eh? :)
You had a few problems in your original code... besides NOT using K&R. :P
1. for (cnt =0; cnt <= 99; cnt++);
Yep, the semicolon doesn't belong there.
2. nums [cnt] = nums[cnt] + 1;
Also pointed out - you need to initialize the value here otherwise you're incrementing whatever was previously left in memory by one.
3. double test; ..; test -> output[cnt];
Here you declare a double called test and then treat it like a pointer to a double. I'm actually surprised that this error would compile.
PostPosted: Thu Dec 23, 2004 4:48 pm
Team Member Top 100
Team Member Top 100
3. I pointed this out, and he explained he had compiled it, then changed it and posted it and changed it back. It wouldn't compile with that ;)
PostPosted: Sat Dec 25, 2004 5:24 pm
Well seeing as im just playing a round with C++ right now
1.) Added that in a test to see what would happend
2.) Completely forgot about intializing arrays in C++ (havent had java but im guessing that too and probably every other language cept VB.net)
3.) Was just fooling around with that.
Also I dont know what K&R is but im guessing its a C++ convention? Please remember im a first year Comp Sci major so I have alot of learning to do.
PostPosted: Sat Dec 25, 2004 8:34 pm
Team Member Top 100
Team Member Top 100
It's actually a C convention by two authors:
Kernighan and Richie.
http://www.softpanorama.org/Bookshelf/C ... book.shtml
PostPosted: Mon Dec 27, 2004 12:24 pm
Hi,
Was looking at the posts.
The solution indeed is in the initialization, however the fix that was posted
nums[cnt] += cnt;
will most likely suffer from the same problems. The += adds "cnt" to its original value, which is still whatever happens to be in memory when you declared the array.
Something like this will work:
nums[cnt] = cnt+1;
(I assume that you want the array to have the values 1-100? Btw, if so, you only need declare a [100] size array, not [101]).
Another simpler option is to use the memset() method. This will zero out the memory in the array and effectively make the array initialized to all zeroes - then you can add whatever you want in it (I'm at my in-laws house on a Win98SE box btw, so no access to any compilers or reference - you'll have to look up memset).
Hope that helps
-a
