It is currently Sat May 18, 2013 12:26 am
 Post subject: Need help with my project in vb.net
PostPosted: Wed Jun 11, 2008 9:33 am
So i have to make a simple adding and subtracting calculator. The problem is thati don't know how to make vb.net display negative numbers. For example when i do 40-99 it gives me 59 instead of -59. Heres mt code:
Option Strict On
Public Class frmCalculator
    Dim total1, total2 As Double
    Private Sub btn1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn1.Click
        txtDisplay.Text = txtDisplay.Text & btn1.Text
    End Sub
    Private Sub btn2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn2.Click
        txtDisplay.Text = txtDisplay.Text & btn2.Text
    End Sub
    Private Sub btn3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn3.Click
        txtDisplay.Text = txtDisplay.Text & btn3.Text
    End Sub
    Private Sub btn4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn4.Click
        txtDisplay.Text = txtDisplay.Text & btn4.Text
    End Sub
    Private Sub btn5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn5.Click
        txtDisplay.Text = txtDisplay.Text & btn5.Text
    End Sub
    Private Sub btn6_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn6.Click
        txtDisplay.Text = txtDisplay.Text & btn6.Text
    End Sub
    Private Sub btn7_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn7.Click
        txtDisplay.Text = txtDisplay.Text & btn7.Text
    End Sub
    Private Sub btn8_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn8.Click
        txtDisplay.Text = txtDisplay.Text & btn8.Text
    End Sub
    Private Sub btn9_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn9.Click
        txtDisplay.Text = txtDisplay.Text & btn9.Text
    End Sub
    Private Sub btn0_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btn0.Click
        txtDisplay.Text = txtDisplay.Text & btn0.Text
    End Sub
    Private Sub btnAdd_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnAdd.Click
        total1 = total1 + Val(txtDisplay.Text)
        txtDisplay.Clear()
    End Sub
    Private Sub btnClear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnClear.Click
        txtDisplay.Clear()
    End Sub
    Private Sub btnEqual_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnEqual.Click
        total2 = total1 + Val(txtDisplay.Text)
        txtDisplay.Text = CStr(total2)
        total1 = 0
    End Sub
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        total1 = total1 - Val(txtDisplay.Text)
        txtDisplay.Clear()
    End Sub
End Class
PostPosted: Wed Jun 11, 2008 11:33 am
Is there a display property for the text box?
PostPosted: Wed Jun 11, 2008 2:49 pm
no its only .text
PostPosted: Wed Jun 11, 2008 3:06 pm
txtDisplay.Clear()
End Sub
try changing the line to this
total1 = Val(total1) - Val(txtDisplay.Text)
PostPosted: Wed Jun 11, 2008 8:26 pm
ok i tried that but it doesnt work.
PostPosted: Sat Jun 14, 2008 4:39 pm
Team Member [Top 500]*
I am not sure what you are doing? I count ten buttons on the form?
I would create a simple form like this:
Three text boxes on the form. TextBox1, TextBox2 and TextBox3. Use labels for Variable1, Variable2 and Result. Place the operators on the form using radio buttons.
The code for this looks like this:
Public Class Form1
    Inherits System.Windows.Forms.Form
    'Declare FirstNum and SecondNum variables
    Dim FirstNum, SecondNum As Double
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
        End
    End Sub
        'Assign text box values to variables
        FirstNum = TextBox1.Text
        SecondNum = TextBox2.Text
        'Determine checked button and calculate
        If RadioButton1.Checked = True Then
            TextBox3.Text = FirstNum + SecondNum
        End If
        If RadioButton2.Checked = True Then
            TextBox3.Text = FirstNum - SecondNum
        End If
        If RadioButton3.Checked = True Then
            TextBox3.Text = FirstNum * SecondNum
        End If
        If RadioButton4.Checked = True Then
            TextBox3.Text = FirstNum / SecondNum
        End If
    End Sub
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    End Sub
End Class
This is pretty much right out of Chapter 5 Visual Basic.NET Step by Step by Michael Halvorson.
There should be no problem displaying a negative number and nothing is needed.
Note the Radio Buttons are placed in a Group Box! That allows only one to be checked (True) of the group.
<EDIT>
To make it simple the entire source code and form can be found here as a sample:
http://www.bearblain.com/downloads.htm
Just download the zip folder saving to a location on your machine. Right click on the zip folder and extract the contents to a convenient location. Open VB.NET and navigate to the files and open them. Hope that helps.
</EDIT>
Ron
PostPosted: Mon Jun 16, 2008 7:39 am
heres the problem reloadron, we haven't gotten to radio buttons so we have to use regular buttons.
PostPosted: Mon Jun 16, 2008 8:12 am
For more efficiency, you can rewrite his if statements like this.
       Else If RadioButton2.Checked = True Then
       Else If RadioButton3.Checked = True Then
       Else If RadioButton4.Checked = True Then
       Else
            msgbox("No operator was selected.", "Error")
        End If
    End Sub
I did not have a computer with VB.NET near me so I could not double check to make sure I wrote the code correctly, but this code would give you a call back if there was no radio button selected in the group.
PostPosted: Mon Jun 16, 2008 10:29 am
OK, then create a form and place 3 text boxes on your form. Then add some buttons using four buttons for the basic operators of Addition, Subtraction, Multiplication and division. Something like this:
A download of a sample may be found here:
It is the basic calc program.
Hope that helps.
Button code looks like this:
    End Sub
    Private Sub Button5_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button5.Click
        TextBox1.Text = ""
        TextBox2.Text = ""
        TextBox3.Text = ""
    End Sub
    End Sub
    Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button3.Click
    End Sub
    Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
    End Sub
End Class
Ron
