It is currently Thu May 23, 2013 2:24 pm
 Post subject: c++ slot machine
PostPosted: Mon May 26, 2008 5:42 pm
i an thinking of making a slot machine program in c++
here is what it should do. roll slots, randomly generates the number. for everytime you win, you get 4 dollars, every play costs 1 dollar. the random number should be somewhere between 1 to 5. if the random number is all fives the player gets 100 dollars. Here is what i have so far, but its not working. Could you please tell me what to do.
#include <iostream>
#include <cstring>
#include <stdlib.h>
#include <time.h>
using namespace std;
void Slotstart ();
void Slotplay ();
int money;
int maxrand;
int result;
int rannum;
int winnum;
int main()
  char name[50];
  cout<<"Please enter your name: ";
  cin.getline ( name, 50 );
  cout<<"Welcome to Virtual Slot machine, "<< name  <<" \n";
  cout<<"Press enter to continue\n";
  cin.get();
  Slotstart();
void
Slotstart ()
     money = 2;
     maxrand = 2;
cout<<"Press enter to pull the slot machine.\n";
cout<<"Press ""leave"" anytime to stop playing.\n";
cin.get();
srand( (unsigned)time( NULL ) );
rannum = rand() % maxrand;
Slotplay ();
void
Slotplay ()
PostPosted: Tue May 27, 2008 7:23 am
... um ... finish writing your code?
Actually, before you do that, I strongly recommend designing the entire program in pseudocode .. THEN flesh it out with proper C++ code. That way, you can think your way through the problem before you try to translate it into a language with which you are largely unfamiliar.
PostPosted: Tue May 27, 2008 1:44 pm
here it is, but it won't compile, it says something about SlotRestart() can't be used as a funtion or void.
#include <iostream>
#include <cstring>
#include <stdlib.h>
#include <time.h>
void SlotRestart;
int slota;
int slotb;
int slotc;
int main()
  char name[50];
  cin.get();
cin.get();
srand(time(0));
    slota=rand()%3;
    slotb=rand()%3;
    slotc=rand()%3;
    if(slota==slotb && slotb==slotc && slotc==slota)
    cout<<"You win\n";
    else
    cout<<"You lose\n";
    cin.get();
    SlotRestart();
void
SlotResult ()
cin.get();
srand(time(0));
    slota=rand()%3;
    slotb=rand()%3;
    slotc=rand()%3;
    cout<<"You win\n";
    SlotRestart();
    else
    cout<<"You lose\n";
    cin.get();
    SlotRestart();
PostPosted: Tue May 27, 2008 4:24 pm
change void SlotRestart; to void SlotRestart(); line 8
change void SlotResult (){ to void SlotRestart(){ line 47
add curly brackets to the last if block (in SlotRestart()) lines 58 to 66
PostPosted: Tue May 27, 2008 4:48 pm
i changed it to what mag said, but now it highlights "else" in slot 64. It says:
In funtion 'void SlotRestart()'
expected primary-function before 'else'
expected ';' before 'else'
thanks
PostPosted: Wed May 28, 2008 6:41 am
These are simply syntax errors .. you need to learn to debug these if you intend to do any programming.
What book are you using to learn? Is this for a course?
PostPosted: Wed May 28, 2008 11:44 am
i am doing this by myself, not for a course, i use the guide on cprogramming.org.
PostPosted: Wed May 28, 2008 11:49 am
i fixed it by deleting void SlotRestart in line 62, but now if you run it, it will do you lose for about 20 times in a row, and then you win for 5 times in a row, and you lose 20 times in a row, and so on.
PostPosted: Wed May 28, 2008 2:31 pm
look over their guide on if structures again
hint, you want
cout<<"You win\n";
SlotRestart();
to execute if they win
you want
cout<<"You lose\n";
cin.get();
SlotRestart();
to execute if they lose
PostPosted: Wed May 28, 2008 4:17 pm
i want SlotRestart to start no matter what, so they don't have to reopen the program to play the slot machine again.
PostPosted: Wed May 28, 2008 7:02 pm
Million Club - 5 Plus*
Hint: Always use braces with if statements. It makes your life a lot easier and avoids problems like you have currently
PostPosted: Wed May 28, 2008 7:47 pm
Monkey Federation (Top 10)*
Good advice, at least until you get better with the syntax...
PostPosted: Fri May 30, 2008 6:21 pm
You know, this would be a good situation for a do...while statement.
