It is currently Wed May 22, 2013 12:47 am
 Post subject: Jass?
PostPosted: Sat Apr 19, 2008 12:43 pm
I was looking over some code in Jass, and was wondering how this would work.
function SaveLoad_Id2CId takes integer n returns integer
    local integer i = n / (256 * 256 * 256)
    local integer r
    set n = n - i * (256 * 256 * 256)
    set r = udg_SaveLoad_Compress[i]
    set i = n / (256 * 256)
    set n = n - i * (256 * 256)
    set r = r * 64 + udg_SaveLoad_Compress[i]
    set i = n / 256
    return r * 64 + udg_SaveLoad_Compress[n - i * 256]
endfunction
If I set n to lets say, 35, wouldn't it just divide it by 256 cubed, set n to 0 based on the math it created, set i to 0, then set n to 0 overwriting its 0 again, set i to 0 again also, and just defeat the purpose of the second set of set i and n's that set them to 0 a second time. Or does it set them, and when it reaches a set r, redoes the local's and goes back to where it left off?
