It is currently Sat May 18, 2013 12:50 am
 Post subject: Problem with some assembly code
PostPosted: Thu Apr 03, 2008 8:48 pm
Trying to finish up a homework assignment. I have no idea why my interrupt isn't working. The simulator gets to the "wai" command and pauses like it should, but nothing happens when I hit a button on my keypad.
What it should do:
http://www.eng.auburn.edu/~sylee/ee2220/hw08S_9.pdf
What my code looks like so far:
;* Stephan Henning                                               *
;* April 4, 2008                                                 *
;* Elec 2220                                                     *
;* Computer Systems                                              *
;* HW9                                                           *
; export symbols
            XDEF Entry            ; export 'Entry' symbol
            ABSENTRY Entry        ; for absolute assembly: mark this as application entry point
; include derivative specific macros
            ;INCLUDE 'mc9s12c32.inc'
ROMStart    EQU  $4000  ; absolute address to place my code/constant data
RAMStart    EQU  $0800
TSCR1       EQU  $0046
TFLG2       EQU  $004F
NTOFS       EQU   122
PORTA       EQU  $0000  ; port for led
PORTB       EQU  $0001  ; port for button columns
PTAD        EQU  $0270  ; port for button rows
DDRA        EQU  $0002
DDRB        EQU  $0003
DDRAD       EQU  $0272
INTCR       EQU  $001E
IRQEN       EQU  %01000000
; variable/data section
            ORG RAMStart
leds    ds.b    1    ; define leds to 1 byte
st1     ds.b    1    ; extras if needed
st2     ds.b    1
mode    ds.b    1    ; mem for storing mode
step    ds.b    1    ; mem for storing iteration step.
mask    dc.b    $FE, $FD, $FB, $F7, $EF
; Insert here your data definition.
; code section
            ORG   ROMStart
Entry:
            ;ldaa #%10000001          ;load aa with initial condition for leds
            ;staa leds                ;store initial conidtion to leds
            movb #%10000001, leds     ;minimized code, same as above
            lds  #$1000              ; initialize stack
            movb #$FF,DDRB           ; port b output
            movb #$00,DDRAD         ; port e input
            movb #$FF,DDRA           ; port a output
            movb leds,PORTA           ; send value to leds
            bset INTCR, IRQEN
            cli
start:
            wai
            bra start
;check_again:
            ;ldaa PORTB
            ;bita #%00000011
            ;lbeq  check_again
            ;bita #%00000001
            ;lbeq  loop1
            ;bita #%00000010
            ;lbeq  loop2
            ;lbra  check_again
loop1:
            ldaa  #$01               ; load a mode 1
            ldab  #$04
loop1_1:
            pshb
            psha
            jsr   shift              ; jump to shift subroutine
            pula
            pulb
            jsr   one_sec_delay      ; lbranch to software delay
            dbne  b,loop1_1
            rts
loop2:
            ldaa  #$00               ; load a mode 2
            ldab  #$06
loop2_1:
            pshb
            psha
            pula
            pulb
            dbne  b,loop2_1
            rts
one_sec_delay
            psha
            ldaa  #NTOFS
  ttloop:
            movb  #$80 , TSCR1
            movb  #$80 , TFLG2
  tloop:    brclr TFLG2, #$80, tloop
            dbne  a, ttloop
            movb  #$00, TSCR1
            pula
            rts
shift                                ; start shift subroutine
            tsta                     ; check a for mode
            bne   mode1
            lbra   mode2
mode1:                               ; lbranch for mode1
            ldaa  #$02
            sba
            blt   mode1_in
            lbra   mode1_out
            rts
mode2:                               ; lbranch for mode2
            ldaa  #$03
            sba
            blt   mode2_in
            lbra   mode2_out
            rts
mode1_in:                           ; shifts mode1 led's in
           ldaa leds                ; load a with leds
           ldab leds                ; load b with leds
           anda #%11100000          ; remove unneeded values in a
           andb #%00011111          ; remove unneeded values in b
           lsra                     ;do the required shifts
           lslb
           lslb
           lbra store_return
           ;stab st2                 ;store to a temp mem location
           ;oraa st2                 ;or a with what we stores in st2
           ;staa leds                ;store a in leds
           ;rts
mode1_out:                           ;shifts mode1 led's out
           ldaa leds                 ;load a with leds
           ldab leds                 ;load b with leds
           anda #%11100000           ;remove unneeded values in a
           andb #%00011111           ;remove unneeded values in b
           lsla                      ;do required shifts
           lsrb
           lsrb
           lbra store_return
           ;stab st2                  ;temp store b in mem
           ;oraa st2                  ;or a with b that we stored in mem
           ;staa leds                 ;store result into leds
           ;rts
mode2_in:
           anda #%11110000          ; remove unneeded values in a
           andb #%00001111          ; remove unneeded values in b
           lslb
           lbra store_return
           ;rts
mode2_out:
           anda #%11110000           ;remove unneeded values in a
           andb #%00001111           ;remove unneeded values in b
           lsrb
           lbra store_return
           ;rts
store_return:
           rts
keypad
            ldx   #mask
  checkcol1:
            movb  #%11111110, PORTB
            ldaa  PTAD
            bita  $FF
            lbeq   checkcol2
            bita  1,x+
            lbeq   butt0
            bita  1,x+
            lbeq   butt4
            bita  1,x+
            lbeq   butt8
            bita  1,x+
            lbeq   buttc
            bita  1,x+
            lbeq   buttleft
            lbra   done
  checkcol2:
            movb  #%11111101, PORTB
            ldaa  PTAD
            bita  $FF
            lbeq   checkcol3
            bita  1,x+
            lbeq   butt1
            bita  1,x+
            lbeq   butt5
            bita  1,x+
            lbeq   butt9
            bita  1,x+
            lbeq   buttd
            bita  1,x+
            lbeq   buttright
            lbra   done
  checkcol3:
            movb  #%11111011, PORTB
            ldaa  PTAD
            bita  $FF
            lbeq   checkcol4
            bita  1,x+
            lbeq   butt2
            bita  1,x+
            lbeq   butt6
            bita  1,x+
            lbeq   butta
            bita  1,x+
            lbeq   butte
            bita  1,x+
            lbeq   buttz
            lbra done
   checkcol4:
            movb  #%11110111, PORTB
            ldaa  PTAD
            bita  $FF
            lbeq   done
            bita  1,x+
            lbeq   butt3
            bita  1,x+
            lbeq   butt7
            bita  1,x+
            lbeq   buttb
            bita  1,x+
            lbeq   buttf
            bita  1,x+
            lbeq   buttblank
            lbra done
   butt0:
            lbra done
   butt1:
            jsr   loop1
            lbra done
   butt2:
            jsr   loop2
            lbra done
   butt3:
            lbra done
   butt4:
            lbra done
   butt5:
            lbra done
   butt6:
            lbra done
   butt7:
            lbra done
   butt8:
            lbra done
   butt9:
            lbra done
   butta:
            lbra done
   buttb:
            lbra done
   buttc:
            lbra done
   buttd:
            lbra done
   butte:
            lbra done
   buttf:
            lbra done
   buttleft:
            lbra done
   buttright:
            lbra done
   buttz:
            lbra done
   buttblank:
            lbra done
  done:
    rti
;*                 Interrupt Vectors                          *
            ORG   $FFFE
            DC.W  Entry           ; Reset Vector
            ORG   $FFF2
            dc.w  keypad          ; keypad interupt
Any ideas?
