It is currently Fri Feb 27, 2015 6:30 pm
 Post subject: Anyone program with 4D before?
PostPosted: Wed Dec 08, 2004 1:24 pm
Just curious....
PostPosted: Sat Dec 11, 2004 6:02 pm
Team Member Top 100
Team Member Top 100
If you consider the fourth dimension as time, then if you calculate things in motion, isn't that 4D?
I wouldn't know though; I have no idea if that's even remotely correct. Any Super String Theorists here want to help out?
PostPosted: Mon Dec 13, 2004 6:16 am
the 4D or 4th Dimension I'm referring to is a database programming language. http://www.4D.com/
PostPosted: Mon Dec 13, 2004 7:40 pm
Team Member Top 100
Team Member Top 100
Oh. :lol:
Why not just stick with MySQL? It and Oracle are the most widely used database solutions. Unless you have to go with that, I'd say stick with one of those two.
PostPosted: Thu Dec 23, 2004 2:33 pm
Bitchin' Fast 3D Z8000*
Kybo_Ren wrote:
Oh. :lol:
<rant>
Just for the record, MySQL is a royal pita at times. In fact, probably shouldn't even be called a database. Transactions and MySQL just don't get along which is why you see it being used very frequently for forums like this one and hardly ever for more critical applications.
Check this out...
http://openacs.org/philosophy/why-not-mysql.html
While some of it is dated, a surprising amont is still relevant.
</rant>
PostPosted: Thu Dec 23, 2004 2:34 pm
Have you tried it now? If so, what is it like?
PostPosted: Thu Jan 06, 2005 1:10 pm
"Have you tried it now? If so, what is it like?"
We've been running it at my work for years. Its a great database when you need to get something done quick. The learning curve is a bit steep, but once you know what you are doing you can do anything.
