It is currently Wed May 22, 2013 11:48 pm
 Post subject: C++ Recursion issue
PostPosted: Fri Mar 07, 2008 7:51 am
Monkey Federation (Top 10)*
#1 Yes this is homework
#2 I have it working there is one small issue
#3 I just want to be pointed in the right direction or shown where my thinking is off
This problem takes an expression 10 + 10 and evaluates it, the problem is that if I do 10 + (2-1) + anything else it will not evaluate anything after the close paren. I have noted a couple spots where I think the issue could lie but cannot seem to make it work. I think my problem is that the RIGHT_PAREN return is not handled correctly (that is a part of the code that was provided), I have noted them below with comments.
Most of this code was provided so the architecture of the program is not mine and cannot be changed. That is just a limitation of the assignment.
// Main.cpp
#include "Parse.h"
int main()
    Parse parser;
    string exp;
    bool continueFlag = true;
    while(continueFlag)
        cout << "Enter in an expression (enter quit to exit loop)" << endl;
        getline(cin, exp);
        if (exp == "quit") continueFlag = false;
        else
            try
                parser.setExpression(exp);
                int value = parser.eval();
                cout << endl << "The value of your expression = " << value << endl;
            catch (Error e)
                cout << "Exception received: "<< endl;
                cout << e.getMsg() << endl;
// Parse.h
#include <iostream>
#include <string>
using namespace std;
enum TokType {NUMBER, VARIABLE, PLUS, MINUS, MULTIPLY, DIVIDE,
              RIGHT_PAREN, LEFT_PAREN, END, WHITE_SPACE, ILLEGAL};
class Token
public:
    TokType type;
    int intValue;
class VarToken : public Token
public:
    string varName;
class Error
private:
    string m_msg;
public:
    Error(const char * err, const char * src, int loc);
    Error(const char *err);
    const char * getMsg();
class Scan
private:
    string m_source;
    int m_srcLen;
    int m_currLoc;
    int m_nextLoc;
    VarToken m_currToken;
    bool whiteSpace(char c);
    TokType getType (char c);
public:
    Scan();
    void setExpression(string & expressionSource);
    VarToken peekToken();   // return the current token we are on (no scan movement)
    void  nextToken();   // go to the next token
    VarToken getToken();    // equivalent to peekToken followed by nextToken
    int currLoc();
class EvalVariable
public:
    void eval (VarToken & variable);
class Parse
public:
    Parse ();
    Parse (string &expSource);
    int eval();
private:
    string m_source;
    Scan scanner;
    EvalVariable evalVariable;
    int expression();
    // Rules processed by the expression routine
    // expression --> - expression
    // expression --> + expression
    // expression --> term
    // expression --> term + expression
    // expression --> term - expression
    int term();
    // Rules processed by the term routine
    // term -->(expression)
    // term --> value
    // value --> number
    // value --> variable
    // term --> value * term
    // term --> value / term
// Parse.cpp
#include "Parse.h"
Parse::Parse ()
Parse::Parse (string &expSource)
    setExpression(expSource);
void Parse::setExpression(string & expressionSource)
    scanner.setExpression(expressionSource);
    m_source = expressionSource;
int Parse::eval()
    // We might have some other initialization to do if this
    // were inside of a real compiler.
    return expression();
int Parse::expression()
    int value = term();
    Token tok = scanner.peekToken();
    if (tok.type == MINUS)
        // Fill in Details
      scanner.nextToken();
      value -= expression();
    else if (tok.type == PLUS)
        // Fill in Details
      value += expression();
    return value;
int Parse::term()
    // term --> value
    // value --> number
    int value ;
    VarToken tok = scanner.peekToken();
    switch (tok.type)
    case VARIABLE:
        evalVariable.eval(tok);
        // Note that we want to fall into the next case
        // statement (i.e. the number code)
    case NUMBER:
            // Fill in Details
      value = tok.intValue;
        break;
    case LEFT_PAREN:
            // Fill in Details
      value = term();
        break;
    default:
        throw Error("term contains illegal character ", m_source.c_str(), scanner.currLoc());
    }// end of switch
    if (tok.type == MULTIPLY)
            // Fill in Details
         value *= term();
    else if (tok.type == DIVIDE)
            // Fill in Details .... Make sure you check for divide
            // by zero.  Throw an exception if you find it.
         value /= term();
    return value;
// Scan.cpp
#include "Parse.h"
Error::Error(const char * err, const char * src, int loc)
    m_msg = err;
    char cbuff[50];
    sprintf(cbuff," at location: %d in \r\n", loc);
    m_msg += cbuff;
    m_msg += src;
Error::Error(const char *err)
    m_msg = err;
const char * Error::getMsg()
    return m_msg.c_str();
Scan::Scan()
    string init ="";
    setExpression(init);
void Scan::setExpression(string & expressionSource)
    m_currLoc = 0;
    m_nextLoc = 0;
    m_srcLen = m_source.length();
    nextToken();
VarToken Scan::peekToken()   // return the current token we are on (no scan movement)
    return m_currToken;
void Scan::nextToken() // go to the next token
    m_currToken.intValue = -1;
    //skip white space
    while(m_nextLoc < m_srcLen && whiteSpace(m_source[m_nextLoc]))
        m_nextLoc += 1;
    if (m_nextLoc >= m_srcLen)
        m_currToken.type = END;
        return;
// The RIGHT_PAREN return goes here but I cannot see where it is handled
    TokType nextType = getType(m_source[m_nextLoc]);
    m_currToken.type = nextType;
    m_currLoc = m_nextLoc++;
    if (nextType == NUMBER)
        while(m_nextLoc < m_srcLen && getType(m_source[m_nextLoc])== NUMBER)
            m_nextLoc += 1;
        // compute value:
        int value = 0;
        for (int i= m_currLoc; i < m_nextLoc; i++)
            value = value *10 + (m_source[i] - '0');
        m_currToken.intValue = value;
    else if (nextType == VARIABLE)
        while (m_nextLoc < m_srcLen)
            TokType t = getType(m_source[m_nextLoc]);
            if (t == NUMBER || t == VARIABLE) m_nextLoc += 1;
            else break;
        m_currToken.varName = m_source.substr(m_currLoc, m_nextLoc - m_currLoc);
VarToken Scan::getToken()    // equivalent to peekToken followed by nextToken
    VarToken retval = m_currToken;
    nextToken();
    return retval;
int Scan::currLoc()
    return m_currLoc;
bool Scan::whiteSpace(char c)
        if (c == ' ' || c == '\t' || c=='\r' || c=='\n') return true;
        return false;
TokType Scan::getType (char c)
       switch(c)
       case '+':
           return PLUS;
       case '-':
           return MINUS;
       case '*':
           return MULTIPLY;
       case '/':
           return DIVIDE;
       case '(':
           return LEFT_PAREN;
       case ')':
// This return does not have any processing statements
           return RIGHT_PAREN;
       default:
           if (c >= '0' && c <= '9') return NUMBER;
           if (c >= 'a' && c <= 'z') return VARIABLE;
           if (c >= 'A' && c <= 'Z') return VARIABLE;
           if (c == '_' || c == '$') return VARIABLE;
       if (whiteSpace(c)) return WHITE_SPACE;
       throw Error("Illegal character", m_source.c_str(), m_nextLoc);
// EvalVariable.cpp
#include "Parse.h"
void EvalVariable::eval (VarToken & variable)
    cout << variable.varName <<  " = ?" << endl;
    int value ;
    string exp;
    getline(cin, exp);
    variable.intValue = atoi(exp.c_str());
[/code]
PostPosted: Tue Mar 11, 2008 9:33 am
Well...I don't know how robust your instructor wants this parser. And I don't know how much to tell you, so I'll give it a shot and hopefully not end up doing your homework for you.
This is just a quick patch... If you change the logic of the "expression" function, then that will get you over the first hump of your parser stopping after the closing paren. Now it may be more elegent to handle this elsewhere, but I hope this helps:
    int value = term();
    Token tok;
    do {
            // Fill in Details
            // Fill in Details
        else if (tok.type == RIGHT_PAREN)
          break;
    } while (tok.type != END);
    return value;
PostPosted: Thu Mar 13, 2008 5:52 am
Thanks for looking it over. I had already turned it in and failed miserably trying to get the right paren working. Guess I was over thinking the whole issue; I was trying to find a way to end the recursive call and I guess I really didn't need to.
Thanks, at least I know I should not make things harder for myself than they have to be.
PostPosted: Thu Mar 13, 2008 7:41 am
Ah...bummer. I was hoping to help you get it working before you had to turn it in. :( At least you know what went wrong.
