It is currently Mon May 20, 2013 7:13 pm
 Post subject: Programming Practice
PostPosted: Fri Feb 01, 2008 6:54 pm
Hi all fellow programmers. I thought I would share a resource that I have come across with you guys.
www.projecteuler.net/
This is an excellent way to get practice on your programming and it doesn't matter what language you know.
PostPosted: Sat Feb 02, 2008 1:01 am
Bitchin' Fast 3D Z8000*
Very cool site. I went ahead and solved the fairly easy problem #50.
In the past, I've always recommended TopCoder to people needing practice problems and now I have one for people specializing a bit more in math problems... awesome!
Comparing the two sites, TopCoder is a better choice for someone practicing for an actual programming contest. You just can't practice for a real contest without having a clock ticking in the background making you insane! Also, if you need practice with more general algorithmic techniques, then TopCoder is again a better choice (especially since they've added problem statistics and categories). However, I really like Project Euler and if you want to learn a little math while practicing programming then it is going to be hard to beat. I'll certainly be spending some time there.
I've got to remember to tell Adak and Manta about this one. Great post -- glad to see that someone else around here uses a computer to 'compute' something! =)
PostPosted: Sat Feb 02, 2008 2:01 am
Problem #5 has a incredibly elegant solution. Beautiful.
PostPosted: Sat Feb 02, 2008 5:16 am
did you get a solution for problem #5 that solves it under a minute?
PostPosted: Sat Feb 02, 2008 9:51 am
Smithfield*
Smithfield*
I'm not very good at number theory, care to explain. Does it take less than 19 multiplications?
PostPosted: Sat Feb 02, 2008 12:22 pm
Team Member Top 100
Team Member Top 100
I think he just means that it the Euclidean algorithm and the prime factorization method give really quick qolutions.
http://en.wikipedia.org/wiki/Least_common_multiple
PostPosted: Sat Feb 02, 2008 12:33 pm
Problem #5 can actually be solved by hand if you have a calculator or function that computes the LCM of two numbers.
Those of you who don't wish to spoil a great little problem should stop reading now! LCM is a big hint btw.
Let's do the example problem by hand. The first observation is that you never have to solve for the entire set of integers. The integers in {1 - 5} are multiples of those in {6 - 10}.
1 * 2 = 2;
2 * 2 = 4;
4 * 2 = 8;
We can get rid of 1, 2, and 4 because they're all multiples of 8. The same is true for 3 and 5 and we're now left with the set {6 - 10}. The second observation is that we're actually trying to find multiples of the numbers in the set and LCM would be the correct answer if there were only two numbers.
My notation for a stack is going to be {bottom of stack, ..., top of stack}. The algorithm/problem is just beautiful. Push the numbers onto a stack, then pop the top two off the stack, compute the LCM for these two numbers, push the LCM onto the stack. Repeat until there is only one number left on the stack.
{6, 7, 8, 9, 10} ==> LCM(10,9) = 90
{6, 7, 8, 90}
{6, 7, x}
{6, x}
{x}
Done. =)
PostPosted: Sat Feb 02, 2008 12:37 pm
Well yes you can solve some of these by good old calc and paper and pencil but the point of this is to do it using a programming language and by the time you've done a whole bunch you'll have a nice library of functions. Example functions that calculate prime numbers .. odd even numbers . .. numbers with decimal values . .etc...
PostPosted: Sat Feb 02, 2008 12:41 pm
You snuck that post in on me while I was typing up the solution. LCM is the important observation. Then the question becomes how to use it to solve for more than two numbers. I would be very interested to see a solution that didn't use LCM.
Also, the author should have done it for the set of integers from 1 to 1000. =)
PostPosted: Sat Feb 02, 2008 12:42 pm
Sure. Assuming that the algorithms aren't so naive that it takes a year to get the answer though. =)
PostPosted: Sat Feb 02, 2008 12:44 pm
Team Member Top 100
Team Member Top 100
Haha, I guess I did :)
Your solution is pretty much what I would've done (I would've used a std::deque in C++, same idea though).
PostPosted: Sat Feb 02, 2008 1:15 pm
I actually did that using LISP. I had written the gcd and lcm algorithms a few days ago, then after figuring out the algorithm, I simply used them and the built in stack to push and pop the numbers. Having a stack just setting there in the interpreter is pretty nice. =)
The other method that I think should work is to find the prime factors of every number in the input set. Put all of the primes into a set then multiplying them together should give the correct answer as well. That's going to be quite a bit slower though.
PostPosted: Sat Feb 02, 2008 4:05 pm
Team Member Top 100
Team Member Top 100
No, it should be fairly fast. Prime factorization for numbers less than enormous RSA-strength ones isn't that hard, so even for the first thousand numbers it would still be a perfectly acceptable algorithm.
PostPosted: Sat Feb 02, 2008 8:43 pm
Well, I said quite a bit slower than the LCM algorithm. I didn't mean to imply that it would be incredibly slow. I guess 'acceptable' is somewhat open to interpretation.
From a practical point of view, I agree that you can probably solve fairly large instances in under a minute; however, I would bet that the same instance can be solved 3x to 10x faster using LCM (and why would anyone not want to use the pretty LCM algorithm instead!). I just might code up both algorithms and find the break-even point.
In terms of complexity theory, integer factorization is considered a hard problem for which no polynomial time algorithm is known to exist (at least on standard hardware -- see Shor's algorithm). As the number of bits increase.... blah, blah, blah -- you knew that though. =)
PostPosted: Sat Feb 02, 2008 9:24 pm
Problem #149 looks like fun.
PostPosted: Thu Feb 07, 2008 1:40 am
Just out of curiousity... has anybody else solved more than 10 of the problems?
