It is currently Thu May 23, 2013 10:34 am
 Post subject: Visual Basic .net
PostPosted: Sat Nov 03, 2007 1:00 pm
Can i use .net to make websites?
PostPosted: Sat Nov 03, 2007 4:14 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
http://asp.net/
Is that what your are looking for?
Or something like VB Script?
 Post subject: Re: Visual Basic .net
PostPosted: Sat Nov 03, 2007 7:39 pm
You sure can. ASP.NET can be driven by C# or VB.NET. I am sure you could probably do a C++ one if you wanted, but I am not sure why you would want to do that.
PostPosted: Sat Nov 03, 2007 8:57 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Apparently http://www.meebo.com is completely in c++.
PostPosted: Sun Nov 04, 2007 6:08 am
Interesting. I would have figured there would be some magical hackery involved in making it work. I just assumed (rightly or wrongly) that C# and VB.NET had extra tuning to make them ASP.NET ready, where C++ probably did not get that.
PostPosted: Sun Nov 04, 2007 7:37 am
what would be the dis/advantage in using .net to make a website rather than html?
PostPosted: Sun Nov 04, 2007 7:48 am
7yrs+11,000 Posts
7yrs+11,000 Posts
You would still be using html/css to make the page look pretty.
ASP/.net/PHP would be used for dynamic content and web apps.
PostPosted: Sun Nov 04, 2007 8:25 am
Gamer is correct. The disadvantage works the other way around. With plain HTML you can't have very dynamic content. Some will argue that you can do this with javascript (which, becomes known as DHTML, or Dynamic HTML) but that isn't the idea of a full blown server-side scripting (PHP or Classic ASP) language or compiled package (.NET).
PostPosted: Fri Feb 08, 2008 10:05 am
Already adding to this topic, .NET would let you build websites, yes. To answer the question whether or not it's better to use .NET or not, the answer is: it depends.
Blogs and forums tend to use technologies like .NET, Ruby on Rails, JSP, and PHP to display data that is dynamic (data that changes all the time). They are normally stored in a database back end. You use technologies like .NET to get data from a database to display. Because .NET is a real programming framework (a framework is set of objects you use to build something, think of it as a warehouse of parts to build an engine; you can build any kind of engine because you have the items you need to build it), you can build some serious websites with it.
However, if you don't need .NET or similar technologies, you can just write the HTML and put the content in it. It's simpler to use; you don't need to learn .NET, only HTML. However, if you need to change something, then you have to change the HTML and corresponding content. The amount of monotony depends on how often you change the content on the screen. The more often, the more you want to lean on learning .NET or similar technologies.
As a matter of fact, HTML is just the way we display stuff on the web. So learning HTML is part of the whole learning curriculum of learning .NET.
