It is currently Tue Mar 03, 2015 12:00 am
 Post subject: linux device driver help
PostPosted: Sat Nov 20, 2004 7:36 pm
hello everyone. i have to create a device driver in linux (slackware) that functions as a first-in first-out device. the device has to function as a named pipe and allow two or more processes to communicate. to test the fifo i am supposed to run the following commands
$ echo "test > /dev/fifo
$ cat /dev/fifo
test
$ cat /dev/fifo
(no output, since the buffer is empty)
i've written the following code, but i have no idea how to write the function for read and write for the device. any help would be greatly appreciated.
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/fs.h>
/* device name */
#define DEV_NAME "CSC330DRVR"
int fifo_open(struct inode *inode, struct file *filp);
int fifo_release(struct inode *inode, struct file *filp);
ssize_t fifo_read(struct file *filp, char *buf, size_t count, loff_t *f_pos);
ssize_t fifo_write(struct file *filp, const char *buf, size_t count, loff_t *f_pos);
int major = 0;
struct file_operations fops = {
   .read = fifo_read,
   .write = fifo_write,
   .open = fifo_open,
   .release = fifo_release
int init_module(void)
   major = register_chrdev(0, DEV_NAME, &fops);
   printk("registered device with major number %i\n", major);
   return 0;
void cleanup_module(void)
   unregister_chrdev(major, DEV_NAME);
   MOD_INC_USE_COUNT;
   return 0;
   MOD_DEC_USE_COUNT;
   return 0;
ssize_t fifo_read(struct file *filp, char *buff, size_t count, loff_t *f_pos)
PostPosted: Mon Nov 22, 2004 5:11 pm
well no body got back to me on this one, but I ended up figuring it out. I figured i'd post the final code so that people could see it if they were interested.
#include <linux/modversions.h>
#include <linux/config.h>
#include <linux/types.h>
#include <linux/wait.h>
#include <asm/uaccess.h>
#include <linux/string.h>
#include <asm/io.h>
#include <asm/msr.h>
#define DEV_NAME "myfifo"
int major = 0;
static char devchar[255];
static char *dev_Ptr;
   .read = fifo_read,
   .open = fifo_open,
   memset(devchar,0,255);
   return 0;
   dev_Ptr = devchar;
   MOD_INC_USE_COUNT;
   return 0;
   MOD_DEC_USE_COUNT;
   return 0;
   int bytes_read = 0;
   if(*dev_Ptr == 0)
      return 0;
   while(count && *dev_Ptr)
      put_user(*(dev_Ptr++), buf++);
      count--;
      bytes_read++;
   return bytes_read;
   int bytes_written = 0;
   while((count || *dev_Ptr))
      get_user(*(dev_Ptr++), buf++);
      bytes_written++;
      count--;
   } //End while
   return bytes_written;
