It is currently Tue Apr 28, 2015 4:20 am
 Post subject: VB 6.0 Launch A Program
PostPosted: Thu Nov 18, 2004 4:16 pm
Team Member [Top 500]*
First, I am not a programmer. If I had to earn a living with my programming skills, I would starve in a few hours.
I dabble in and mess with VB 6.0 and also have Visual Studio .NET.
I built a simple little login form for the hell of it to learn a little. I played with adding a few twist and case statements. All of that works just fine.
Now what I want to happen, is when a command button is clicked, I want a particular program to open and for the form to close. I tried a Shell and things don't quite work right.
Private Sub Command1_Click()
Shell "F:\Program Files\Jasc Software Inc\Paint Shop Pro 7\psp.exe"
End Sub
What would be a good way to go about this? Just a simple command line to open a program from a command button on my form?
Thanks Guys
Ron
PostPosted: Thu Nov 18, 2004 8:37 pm
Team Member Top 100
Team Member Top 100
Try CreateProcess() or ShellExecute().
For launching a process, CreateProcess() is preferred.
PostPosted: Fri Nov 19, 2004 10:32 am
I got it to work good! I used Shell much like before, however, I was leaving Focus out which is why it would not open the way I wanted it to. Also, the PSP program I was using as an example has a bad file, I really need to fix that, thus I used PSP 8 as an example. Here is what works:
Dim t As Double
t = Shell("F:\Program Files\Jasc Software Inc\Paint Shop Pro 8\Paint Shop Pro.exe", vbNormalFocus)
End Sub
I intend to mess with CreateProcess next. Thanks again.
Ron
