It is currently Wed May 06, 2015 1:39 pm
 Post subject: Image not uploading
PostPosted: Mon Nov 08, 2004 2:45 pm
for some reason the image isn't uploading and i can't seem to find the problem :'(
so here's my form:
echo"<form action=\"index.php\" enctype=\"multipart/form-data\"><input type=\"hidden\" name=\"mode\" value=\"adsm\">";
echo"File: <input type=\"file\" name=\"file\"><br>";
echo"Code: <input name=\"code\"><br>";
echo"<input type=\"submit\" value=\"Add!\">";
echo"</form>";
and my processing page:
<?php
$copy = copy($file,"smile/$file_name");
if($copy){
$q = "INSERT INTO mbsmile (code,img) VALUES ('$code','$file_name')";
$result = mysql_db_query($db,$q);
if($result){
    echo"smiley uploaded successfully";
}else{
    echo"An error occured...";
}else{
   echo"image couldn't be uploaded";
please help...
the error i get:
Warning: copy(!.gif): failed to open stream: No such file or directory in /home/twirp35/public_html/naruto/adsm.php on line 2...
 Post subject: Re: Image not uploading
PostPosted: Tue Nov 09, 2004 8:11 am
So, it is choking on the second line of your php script ... this one:
I would start by checking to ensure that the correct file name is being passed, and that the file exists in that directory (/home/twirp35/public_html/naruto/adsm.php)
PostPosted: Thu Jan 06, 2005 7:03 am
For starters your form has some errors. I added a MAX_FILE_SIZE field for the max size of the image in bytes. You also need to specify an input type for the Code field.
echo"<form action=\"index.php\" enctype=\"multipart/form-data\" method=\"POST\"><input type=\"hidden\" name=\"mode\" value=\"adsm\">";
echo "<!-- MAX_FILE_SIZE must precede the file input field --><input type=\"hidden\" name=\"MAX_FILE_SIZE\" value=\"5242880\" />";
echo"</form>";
Your page handling the uploaded file also doesn't properly handle the uploaded file. Php stores uploaded files in a temp location until you copy them over. After the script is done running the temp files are removed. This rewritten script should work for you. You will need to update the $uploaddir value with the full unix path to where you want these smileys stored.
$uploaddir = "~/smile/"; // remember the trailing slash!
/* Retrieve data from POST */
$MAX_FILE_SIZE = $_POST['MAX_FILE_SIZE'];
$code = $_POST['code'];
$file_name = $_FILES['file']['name'];
/* Error check uploaded file */
if($_FILES['file']['name'] == '') {
  echo "You did not select a file to upload" . $_FILES[$file]['name'];
} elseif($_FILES['file']['size'] == 0) {
  echo 'There appears to be a problem with the file your are uploading, it has a size of 0';
} elseif($_FILES['file']['size'] > $MAX_FILE_SIZE) {
  echo 'The file you selected is too large' . $MAX_FILE_SIZE;
} else {
  $uploadfile = $uploaddir. $_FILES['file']['name'];
  if(move_uploaded_file($_FILES['file']['tmp_name'], $uploadfile)) {
    echo 'Upload file success!<br>';
    $result = mysql_db_query($db,$q) or die("Couldn't execute query.<br>" . mysql_error() . "<br>$q<br>");
  } else {
    echo 'There was a problem uploading your file.<br>';
    print_r($_FILES);
