It is currently Wed Jan 28, 2015 9:00 am
 Post subject: Updating text within a loop
PostPosted: Fri Nov 05, 2004 12:18 pm
Professional Dork
Professional Dork
I'm writing a little proggy that will countdown the time I have left in my job
Without going into the gory details, I have the following snippet of code to give you an idea of what it's like:
Do
    If <<condition>>
        Exit Do
    End If
    lblTimeToGo.Text = datNowTime.Second
    Thread.Sleep(1000)
Loop
The thing is that the label.text never get updated for whatever reason, I assume it's because the app is busy sleeping and processing data.
How can I have the gui change the text on the screen automatically? Another type of loop? Shelling out the sleep command? Other methods?
This is VB.NET, fyi
PostPosted: Fri Nov 05, 2004 4:12 pm
Team Member Top 100
Team Member Top 100
Did you test if the part outside the condition is ever executed? Try a MessageBox there saying, "yo." or something to let you know if it's executed.
PostPosted: Sat Nov 06, 2004 6:00 am
Professional Dork
Professional Dork
I can step through and see the code updating the datNowTime.Second value
PostPosted: Sat Nov 06, 2004 7:30 am
Warning: I know nothing about VB.net
Could the problem having anything to do with the fact that you are assigning an integer value (datNowTime.Second) to a character or string (lblTimeToGo.Text) ? Does VB.net handle these kinds of implied conversions?
I would try testing lblTimeToGo.Text = datNowTime.Second outside of the loop, to see if the assignment works.
Worth a shot, anyway. :)
PostPosted: Sun Nov 07, 2004 8:13 am
Professional Dork
Professional Dork
Without the look code, it works just fine, it just never updates :)
Edit: THis is because Option Strict is off, meaning you can change data types from one to the other. Yes this is dangerous, which is why it's recommended you turn it on (why it's not by default is beyond me). In that case, then you'd get around this problem with the Cstr() command which can convert a numeric data type to string.
PostPosted: Sun Nov 07, 2004 11:51 pm
Bitchin' Fast 3D Z8000*
I'm not familiar with VB, but here is how a simple second clock in Java works:
while (true)
  l.setText( new Date().toString() );
  Thread.sleep(1000);
Notice how I create a new Date object every 1000ms (a Date is an instant in time; whereas a Calendar represents multiple dates/times/etc). Do you need to do something similiar in VB? Just a shot in the dark...
PostPosted: Mon Nov 08, 2004 7:03 am
Professional Dork
Professional Dork
Once again, I find out that it's far easier than I ever imagined.
Add a timer object from Windows Forms, and set it to enabled with a tick event set to once a second, and then run everything out of a Timer_tick subroutine.
It automatically updates itself.
PostPosted: Mon Nov 08, 2004 4:51 pm
Woo! Good to know you solved the problem. :)
PostPosted: Mon Nov 08, 2004 6:17 pm
MS offers something similar as an example.
http://msdn.microsoft.com/library/defau ... otimer.asp
(Got to this one late, I know.)
