It is currently Sat Apr 18, 2015 2:06 am
Post new topic Reply to topic  [ 19 posts ]
 Post subject: Visual Basic Help
PostPosted: Tue Nov 02, 2004 6:54 pm
Hey all,
I have been having some problems with visual basic and they are as follows:
1) I have been trying to find some way to ping a remote server, however i have been unsuccessful in my search
2) I figured that maybe i could run the ping.exe as a shell and read the output from that but, i do not know how to read output from a shell (In other words i would appreciate if someone could tell me how)
3) The people who i am mak,ing this program for are expecting it soon.
Basically what i am trying to do is make a program which minimizes to the task tray (another ordeal) and displays a green dot in the task tray if it can successfully ping a server specified by the user. If it can not reach that server, the dot turns red. However i hit my first problem when i ran into the above three points. Please answer back as this is important.
PS. There is a possibility that this can not be done.
 Post subject: Re: Visual Basic Help
PostPosted: Tue Nov 02, 2004 8:39 pm
short4lif2 wrote:
Hey all,
What version of VB are referring too? VB6? VB.NET? Let us know, VB is a broad term, any details will aid us in helping you. :)
 Post subject: I am using VB.NET
PostPosted: Wed Nov 03, 2004 4:03 pm
Yeah it's vb.net
PostPosted: Wed Nov 03, 2004 8:18 pm
Team Member Top 100
Team Member Top 100
Does it have to be in VB.NET? I can give you a C++ solution.
EDIT:
Here's an idea:
call ping.exe with whatever you want, but then pipe the output to a file (i.e. "ping.exe www.maximumpc.com >log.txt"). Then read the log file in and parse it.
 Post subject: Sorry! Not very helpful
PostPosted: Sat Nov 06, 2004 2:30 pm
I truly appreciate that you tried but i did not quite understand what you meant! If you could rephrase, or if anyone has any ideas, i would appreciate.
PostPosted: Sat Nov 06, 2004 2:33 pm
You have some sort of book or manual right? Winsock should be able to do this pretty easy. Look up the winsock functions.
 Post subject: Re: Sorry! Not very helpful
PostPosted: Sat Nov 06, 2004 3:21 pm
What have you got so far? Anything? What do you need help with, exactly?
So far, it sounds like you are asking us to write the application for you ... which, given that most of us are either professionals or students (and some both) just isn't going to happen.
Well, the professionals might ... but we'd have to talk $ first.
 Post subject: OK sorry about this
PostPosted: Sat Nov 06, 2004 8:22 pm
Sorry about this but the problem thinned out a lot. I started using the Visual Basic Express edition (which rules) and since it uses .NET 2.0 there is actually a ping object. so now, i managed to ping the server, however the only problem is that instead of telling me that it did not work (when it doesn't) it gives me an error. bassically what i did is told it to you use notifyicon1 if it worked and notifyicon2 if it failed. but instead of seeing notifyicon2 i see "you're code is messed BURN!"... although not exactly like that. I am in a hurry so i can't tell you exactly what the error said but it should not be there but thanks!
PostPosted: Sat Nov 06, 2004 8:30 pm
This is why we use error handling routines.
You have to create an error trap that catches the error and, rather than interupt your program, it can send the appropriate message to your notifyicon2.
PostPosted: Sun Nov 07, 2004 3:57 am
Team Member Top 100
Team Member Top 100
It seems you have your problem worked out (at least to the extent that I can help), but if you still want to know what I meant, then read on. If not, then skip it :)
Try this out:
Start > Run > "cmd.exe". Now, get to your desktop. If you're using Windows XP, then type, "cd Desktop". Now, ping a server. Let's use www.maximumpc.com. The command would look like this: "ping.exe www.maximumpc.com". It should give you some data. Now, take advantage of Windows's built-in pipes. A simple stdout pipe would use the '>' sign. To put ping.exe's output in a file called "pinglog.txt", the command would be this: "ping.exe www.maximumpc.com > pinglog.txt". Try it out. After less than a second, maybe a bit more, it will give you back the command prompt. Now look at your desktop. Do you see a file called "pinglog.txt"? It's there. Now, open it up. Here's what it said for me:
Quote:
Pinging www.maximumpc.com [64.191.196.129] with 32 bytes of data:
Reply from 64.191.196.129: bytes=32 time=20ms TTL=246
Reply from 64.191.196.129: bytes=32 time=19ms TTL=246
Reply from 64.191.196.129: bytes=32 time=18ms TTL=246
Ping statistics for 64.191.196.129:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 20ms, Average = 19ms
As you can see, this would be an effective way to use ping.exe and not have to do any work. What I'd suggest is just spitting the file to C:\, then deleting it after you're done with it (and ping.exe is, too).
The only drawback is that you must create a file. Though the file can be deleted, this isn't the ideal solution.
PostPosted: Sun Nov 07, 2004 7:48 am
I'm not familiar with MS scripting (it has been a loooooong time), but can't you pipe the output into something other than a file? It seems silly to require hard drive access for so little data ... piping that output into a buffer and parsing it for the info you need as necessary (and flushing the buffer regularly!) seems a more efficient use of resources, IMO.
PostPosted: Sun Nov 07, 2004 12:35 pm
Team Member Top 100
Team Member Top 100
Sure. You can pipe one program's stdout to another's stdin. But that would mean giving up input. Also, can VB create console applications?
Alternatively, you can look in the MSDN to see if you can find a way to read console output ;) (There is at least one way :))
 Post subject: thanks a lot
PostPosted: Sun Nov 07, 2004 1:39 pm
Wow i did not think that i would get so many replies and i really appreciate. i like the ideas a lot!
 Post subject: i found it
PostPosted: Thu Nov 11, 2004 8:21 am
OK guys i got it to work so if you want the code, here it is
On Error GoTo ErrorHandler
        If My.Computer.Network.Ping(TextBox1.Text) Then
            NotifyIcon2.Visible = True
            NotifyIcon3.Visible = False
        End If
        Timer1.Enabled = True
        If NotifyIcon2.Visible = True Or NotifyIcon3.Visible = True Then
            NotifyIcon1.Visible = False
        End If
        Me.Hide()
        Exit Sub
ErrorHandler:
        Me.Hide()
        NotifyIcon2.Visible = False
 Post subject: Re: i found it
PostPosted: Thu Nov 11, 2004 8:28 am
Professional Dork
Professional Dork
        End If
        End If
        Me.Hide()
        Exit Sub
ErrorHandler:
        Me.Hide()
See, this is the thing with VB.NET. If you're used to version 6 or earlier, you think in the API mindset, and .NET just has all these cool-ass functions built right in.
It can be both infuriating and beautiful.
 Post subject: what?
PostPosted: Thu Nov 11, 2004 5:20 pm
see, i believe that the whole "the hardest way to do it is the most hardcore and cool way to do it" is such a senseless mindset. For that exact reason i am a VB.NET user. All the assembly and C coders are more into the 1 hour of work rather than 5 minutes of work idea. i do not understand how built in features are infuriating.
PostPosted: Thu Nov 11, 2004 5:44 pm
... not everyone runs windows, not all windows users have the NET framework installed, AND many programs require far more than .NET provides.
Having said that ... nice work. :D
 Post subject: Re: what?
PostPosted: Thu Nov 11, 2004 7:14 pm
That's because those Assembly and C coders are usually trying to maximize performance by writing the code themselves. If you write Operating Systems for a living, chances are it will be in C.
That, and no singular language is the end-all-be-all language. Different tools for different jobs, much like you don't use a monkey wrench to screw in a light bulb.
Although VB.NET has its merits, some people actually like the hardcore way of writing things. Sure, it's not necessarily the best way, but it's a challenge to them and some live for the challenge.
PostPosted: Fri Nov 12, 2004 3:46 am
Professional Dork
Professional Dork
While I agree with your "the hardest way to do it is the most hardcore and cool way to do it" point, I should point out that understanding the underlying logic and processes behind what you're doing can be a real benefit when you hit something that .NET doesn't cover.
