It is currently Sat Apr 25, 2015 2:31 pm
 Post subject: .
PostPosted: Tue Oct 26, 2004 3:36 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
PostPosted: Tue Oct 26, 2004 9:06 pm
I judge you GUILTY!
I judge you GUILTY!
I recommend the Deitel and Deitel books on learning C++
or download the free books from www.mindview.net
it's called Thinking in C++
It assumes you know some C, though, but it gives you an excellent intro to the nitty gritty details of C++.
PostPosted: Tue Oct 26, 2004 11:54 pm
Like Dude-X suggested, I highly recommend the Deitel books. That's what I'm actually using to learn C++ right now. It's AWESOME in everyway!!! It teaches the language clearly & it's color coded. It actually teaches you how to program correctly/professionally from the very start. One thing I love about the book is the fact that they give you programming tips all along. There are 601 programming tips in the whole book, and they're classified into 6 types, as follows:
1- 90 Good Programming Paractices: These are tips that'll help you write programs that are more readable, self-documenting & easier to maintain.
2- 198 Common Programming Errors: Tips to help you avoid making some of the most common mistakes that most programers do.
3- 88 Performance Tips: Tips on how to wright your programs for better performance.
4- 36 Portability Tips: Tips that would help you wright portable codes.
5- 149 Software Engineering Observations: Tips that would point out architectural & design issues that has an affect on construction of sofware systems.
6- 38 Testing and Debugging Tips: Tips on how to avoid having bugs as you write your programs that hopefully would make the test & debugging process simplier.
Dietel does this with all their books. I wouldn't recommend anything else. I'll, hopefully, be buying the 6th edition of Java How to Program next month. Good luck. :)
PostPosted: Wed Oct 27, 2004 12:52 am
Bitchin' Fast 3D Z8000*
Personally, I hate the Deitel books (ok, hates a bit strong). You have to sift through a 100 line program to see how 3 lines of code are supposed to work. And I don't give a rats you know what if it is all pretty colors either! Just my .02
There is a link to Bjarne's book in the resource list. Some of the guys here don't like the idea of 'learning' from this book. Personally, I don't think I understood C++ until I read his book and realized how truly mediocre most of the other books really are.
And don't worry about gui's or sound. You have a LONG ways to go before even thinking about those subjects.
PostPosted: Wed Oct 27, 2004 4:41 am
Notched on both sides
Hey Gadget - (yes its me the guy who also gives you sh*t in the folding forum)
Wanted to say thanks for your suggestion - I've dabbled in VB but its been a few years - wanted to learn programming but wanted something, a book, a course, anything that would help me truly and fully understand the language...
Sounds like your suggestion is a great one - wanted to say thanks for posting it!
Tuathal
PS: If you tell anyone in Folding that I was nice to you.. I'll give you SUCH A PINCH! <don't ask me where the archaic Three stooges reference came from...>
PostPosted: Thu Oct 28, 2004 12:23 am
I judge you GUILTY!
I judge you GUILTY!
Gadget's feeling about the Deitel books is a bit too harsh, but there are moments in the book where there is a lot of code to cover a concept.
However it is explained very well.
The Bjarne Stroustrup book explains why C++ does things. There are two books to read The C++ Reference book, and Design and Evolution. The latter book gives you some insight into why C++ works the way it does.
Here are some important points to remember. C++ is a a language that supports object oriented programming. You don't have to use all the features of it to get stuff done.
PostPosted: Thu Oct 28, 2004 1:56 am
Well, I haven't really read Bjarne's book, so there's nothing I can say about it. I guess we all have our own way of learning things, and Deitel suits my learning needs perfectly . :)
