It is currently Wed Mar 04, 2015 8:29 pm
 Post subject: OS text
PostPosted: Tue Oct 26, 2004 11:35 am
Hey folks ... I'm in the market for a good text on operating systems .. fundamentals to advanced knowledge. Ideas?
PostPosted: Tue Oct 26, 2004 2:37 pm
You want one on the internals of all of them? Or specidfic ones? There isn't much "general" info about them. They all work differently.
PostPosted: Tue Oct 26, 2004 3:33 pm
Team Member Top 100
Team Member Top 100
Want fundamentals? Try a book on embedded programming. For advanced stuff, you're porbably going to want to check out a few programming-based forums for suggestions.
PostPosted: Tue Oct 26, 2004 9:03 pm
I judge you GUILTY!
I judge you GUILTY!
There's an Operating Systems book by Tannenbaum.
That's what most good colleges use.
http://www.bookpool.com/.x/pat76ra096/sm/0130313580
I am taking an OS class now, so if you have some easy questions I can help you out.
PostPosted: Wed Oct 27, 2004 12:46 am
Bitchin' Fast 3D Z8000*
Tanenbaum. I put a link to it in the resource guide.
 Post subject: Re: OS text
PostPosted: Wed Oct 27, 2004 7:46 pm
Do you mean like OS development, design techniques, or The Way Your Favorite OS Works?
For OSDev I use http://www.osdever.net, not a text but a pretty fine resource.
I don't really know about texts, other than the one previously mentioned; however, you could try http://www.osnews.com/, I'm pretty sure they have a Resource section with a couple of books.
PostPosted: Wed Oct 27, 2004 8:50 pm
Thanks for the links and suggestions guys. :)
