It is currently Tue Jan 27, 2015 3:57 pm
 Post subject: I have started to learn c++
PostPosted: Wed Oct 20, 2004 5:20 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I got got out of the first few chapters of my C++ book. I am starting to understand the basics :D
PostPosted: Wed Oct 20, 2004 5:34 pm
I wish I was learning C++ :( In my college course, we start out with just basic C. I am used to Java, so this is like going back to the Stone Age. I keep forgetting to do things like tell it to write to addresses rather than variables, and that functions can only return one value.
 Post subject: Re: I have started to learn c++
PostPosted: Wed Oct 20, 2004 6:43 pm
Nice!! :D Good luck, gamer .. and be sure to ask questions if you need some help / extra explanations. :)
PostPosted: Thu Oct 21, 2004 2:16 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Ok i need help, A example program calculater in the book, and i was trying to figure out after the cout comand, what do i put there so users can type text and number. Grr i cant explain my problem correctly.
PostPosted: Thu Oct 21, 2004 6:58 pm
I judge you GUILTY!
I judge you GUILTY!
Use cin to get input and store the input in a variable. For example to read an integer
type:
int number;
cout << "Type a number please: ";
cin >> number;
PostPosted: Thu Oct 21, 2004 8:15 pm
Team Member Top 100
Team Member Top 100
Make sure you are using
"#include <iostream>
using namespace std;
instead of
"#include <iostream.h>
I've found a lot of books that are too old to use the correct form. There are better methods than the "using namespace std;", like "using std::cout" for whatever item from the std namespace you're using, but for now stick to "using namespace std;"
 Post subject: Learning C++
PostPosted: Wed Oct 27, 2004 2:13 am
I spent the whole of last year learning or should I say trying to learn C++. I hated it with a passion, though that might have had something to do with my tutor. He was never that keen to pass on information or explain things. He taught by the 'go out and find it yourself and I'll tell you if you are wrong but not why' method.
In the end I bought a teach yourself book only to find the code in the book wasn't compatible with the shit Borland compiler we were forced to use at the college.
This resulted in me having to do my homework twice, once to fit in with the compiler I got with the book and then alter the code so that Borland would recognise it.
I've since moved on to VB6 and despite a few teething troubles am really getting into it. I'm starting Java after Christmas and cannot wait.
So good luck with your C++. If I can be of any help please ask, cannot guarentee the answer will work on your compiler. :roll:
