It is currently Sun Apr 19, 2015 4:51 pm
 Post subject: Please help C++ n00b!
PostPosted: Tue Oct 19, 2004 2:42 pm
Hi guys,
C++ n00b here, need some help with a homework assignment.
I'm trying to write a win32 console app in C++ using Visual Studio 2003, and am having issues with it.
The program I'm trying to write is basically a set of nested switch statements, and I can't seem to get the system to actually run the nested switches.
I wrote a simplified version of the app while trying to troubleshoot it. Here's what I've got:
#include<iostream>
using namespace std;
int main()
   //declares variables
   char var1;
   char var2;
   //user enters data
   cout<<"enter either a (1) or a (2): "<<endl;
   cin>>var1;
   cout<<"enter either another (1) or another (2): "<<endl;
   cin>>var2;
   //begins nested switch
   switch(var1)
   case 1: //user enters a 1 as first number
      switch(var2)
      case 1: //user enters 1 as second number
         cout<<"you entered a (1) and a (1)"<<endl;
         system("PAUSE");
         break;
      case 2: //user enters 2 as second number
         cout<<"you entered a (1) and a (2)"<<endl;
         system("PAUSE");
         break;
      }//end switch var2
      break;
   case 2: //user enters a 2 as first number
      switch(var2)
         cout<<"you entered a (2) and a (1)"<<endl;
         system("PAUSE");
         break;
         cout<<"you entered a (2) and a (2)"<<endl;
         system("PAUSE");
         break;
      }//end switch var2
      break;
   }//end switch var1
   system("PAUSE");
   return 0;
Then the program essentially ends.
The final app shows this (example):
1
2
Press any key to continue...
Then the program ends. It never displays any of the cout statements written in the switches, and I can't figure out why.
Anyone get what I'm trying to do? What am I doing wrong?
*edit* Forgot about the green code formatting thing
Thanks in advance,
Treklink256
PostPosted: Tue Oct 19, 2004 6:53 pm
Why are they nested? This makes your program unnecessarily complicated.
I think (I'm not sure, because I can't find my reference and I don't use switches very often) that you need to put the character you are checking for in quotes ... so either of these should work:
case "1":
or
case '1':
If you were checking for an integer value, 1 would work .. but since you are checking for a character, I am pretty sure it needs to be in quotes.
At any rate, your program is probably failing because of some minor syntactical error like this one. :D
 Post subject: Let's try something else...
PostPosted: Tue Oct 19, 2004 6:56 pm
Well, I've been fiddling with this thing for a little while now, and tried to re-write it using nested "if" statements instead.
Here's what I wrote:
#include<iostream>
int main()
   char var1;
   char var2;
   //user enters data
   cin>>var1;
   cin>>var2;
   //begins nested ifs
   if(var1 =1)
      if(var2 =1)
         system("PAUSE");
      else if(var2 =2)
         system("PAUSE");
   else//var1 = 2
      if(var2 =1)
         system("PAUSE");
      else//var2 =2
         system("PAUSE");
   return 0;
When written like this, I always end up with the exact same output, regardless of what is entered.
Example:
1
2
press any key to continue...
"You entered a (1) and a (1)". No, I didn't. At least I get SOME output this time...
Any thoughts anyone? Please?
 Post subject: Does anyone actually read these "subject" things?
PostPosted: Tue Oct 19, 2004 7:17 pm
Oh, hello!
Thanks for the suggestion, let me try it out a minute...
*type*type*type*
*build*
*runs exe*
Ha! It was the second one, the
case '1':
thing.
"unnecessarily complicated"... yhea, pretty much. Again this is a simplification of the actual program - not that the real thing is that much more complex - It's part of the assignment, I'm just trying to get it done with.
Thank you! I knew it was something stupid like that :oops:
PostPosted: Tue Oct 19, 2004 7:40 pm
Team Member Top 100
Team Member Top 100
The reason your nested ifs were returning true was because you used = (the assignment operator) instead of == (the equivalency operator).
 Post subject: Re: Does anyone actually read these "subject" thin
PostPosted: Tue Oct 19, 2004 7:51 pm
Absolutely, 100%, NOT stupid.
Computers are fanatical about syntax .. you get it right, or they do very very mischievous things to your program, your data and possibly your gf.
Practice, practice, practice.
PostPosted: Tue Oct 19, 2004 8:02 pm
Team Member Top 100
Team Member Top 100
PostPosted: Sun Oct 24, 2004 8:40 pm
That's an awsome image. Permission to copy it? [Y/N]
PostPosted: Mon Oct 25, 2004 4:54 pm
Team Member Top 100
Team Member Top 100
I didn't make it :)
Yes, it is an awesome image.
It's from www.roflcopter.com
