It is currently Sun May 19, 2013 1:27 am
 Post subject: Echo command
PostPosted: Mon Oct 18, 2004 9:23 am
I know a little C and since Java is kinda like C I am trying to start learnig it.
One of my assignements for my first class is telling me to create a unix style echo command, does this look right? It's not working! Anything I am doing wrong?
It's not printing its arguments:
public class echo {
public static void main {{string argv[]) {
for(int i=0; i < argv.length; i++)
System.out.print(argv[i] + " ");
System.out.print("\n");
System.exit(0);
//Yeah I write purdy code I know :P
PostPosted: Mon Oct 18, 2004 9:40 am
What happens if argv.length = 0?
Try inserting this line just ahead of that one:
System.out.print("Arguments in argv: " + argv.length + "\n");
PostPosted: Mon Oct 18, 2004 11:12 am
It worked!
Thankee thankee!
PostPosted: Mon Oct 18, 2004 2:03 pm
Glad to help. :)
PostPosted: Fri Oct 22, 2004 2:26 am
Bitchin' Fast 3D Z8000*
You shouldn't use argv in Java programming. Gives the impression that it means the same thing as in C. Also, please use the bbcode 'code' tag in the future! Like so....
import java.util.*;
class Echo {
    public static void main (String[] args) {
        System.out.println( Arrays.asList(args).toString().replaceAll("[\\[|\\]]","") );
        System.exit(0);
