It is currently Sat Apr 25, 2015 11:09 pm
 Post subject: Trouble with an assignment
PostPosted: Sat Oct 16, 2004 5:51 pm
Hey guys,
I am trying to debug this program that I wrote for class and am stumped. Any suggestions?
//Fig 3.54: fig04_24.cpp
//Chess Knight
#include <iostream>
#include <iomanip>
using std::cout; //program uses cout
using std::endl; //program uses endl
// Create globals
int moveknight (int);
static int nomoves = 1;
int main()
while (nomoves == 1){ //while loop ends tour
moveknight;
return 0;
// Moves knight around chessboard
int moveknight (nomoves)
static int curhor = 0;
static int curvert = 0;
static int moves = 1;
static int board [8] [8] = {0};
int newhor [8] = {2,1,-1,-2,-2,-1,1,2}; //possible horizental half of moves
int newvert [8] = {-1,-2,-2,-1,1,2,2,1}; //possible horizental half of moves
for (int cntr = 0; cntr<=7; cntr++, moves++){ //for loop to run through possible moves
if (curhor + newhor < 0 || curhor + newhor > 7 || curvert + newvert < 0 || curvert + newvert > 7)
return; //keeps peice on the board
if (cntr == 7 && (board [ curhor + newhor[cntr] ] [ curvert + newvert [cntr] ] == 1)
nomoves = 0; //sets variable to end tour
while (board [ curhor + newhor[cntr] ],[ curvert + newvert [cntr] ] == 0){ //While loop for when move is possible
switch (curvert){ //converts to chessboard units for print
case 0:
cout << "Move " << moves << "\t A";
break;
case 1:
cout << "Move " << moves << "\t B";
break;
case 2:
cout << "Move " << moves << "\t C";
break;
case 3:
cout << "Move " << moves << "\t D";
break;
case 4:
cout << "Move " << moves << "\t E";
break;
case 5:
cout << "Move " << moves << "\t F";
break;
case 6:
cout << "Move " << moves << "\t G";
break;
case 7:
cout << "Move " << moves << "\t H";
break;
default:
break;
switch (curhor){ //converts to chessboard units for print
case 0:
cout << "1 to ";
break;
case 1:
cout << "2 to ";
break;
case 2:
cout << "3 to ";
break;
case 3:
cout << "4 to ";
break;
case 4:
cout << "5 to ";
break;
case 5:
cout << "6 to ";
break;
case 6:
cout << "7 to ";
break;
case 7:
cout << "8 to ";
break;
default:
break;
curhor = curhor + newhor; //move piece horizontally
curvert = curvert + newvert; //move piece vertically
case 0:
cout << "A";
break;
case 1:
cout << "B";
break;
case 2:
cout << "C";
break;
case 3:
cout << "D";
break;
case 4:
cout << "E";
break;
case 5:
cout << "F";
break;
case 6:
cout << "G";
break;
case 7:
cout << "H";
break;
default:
break;
case 0:
cout << "1\n";
break;
case 1:
cout << "2\n";
break;
case 2:
cout << "3\n";
break;
case 3:
cout << "4\n";
break;
case 4:
cout << "5\n";
break;
case 5:
cout << "6\n";
break;
case 6:
cout << "7\n";
break;
case 7:
cout << "8\n";
break;
default:
break;
break;
return nomoves;
PostPosted: Sat Oct 16, 2004 6:10 pm
I judge you GUILTY!
I judge you GUILTY!
Move the main function to the bottom for starters.
Seoond your function
int moveknight(nomoves) is missing the int specifiier
it should be
int moveknight(int nomoves)
Your code has other syntax errors like mssing parantheses.
You might have to use a * for the newver and newhor calculations since the new positions are arrays.
example
if (curhor + *newhor < 0 || curhor + *newhor > 7 || curvert + *newvert < 0 || curvert + *newvert > 7)
 Post subject: Got it
PostPosted: Sat Oct 16, 2004 8:08 pm
Dude,
I figured it out like 5 minutes before your post. Of course, a half dozen other bugs came up next, but I have it running now. Thanks.
G
