It is currently Sat Jan 31, 2015 3:47 pm
 Post subject: Small math programs
PostPosted: Sun Oct 10, 2004 4:50 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
I want to write small programs for my class to do certain kinds of math for me, like compounding interest ect. what language would be best for this?
PostPosted: Sun Oct 10, 2004 5:41 pm
To do simple arithmetic? Whatever language you are most comfortable in, I'd say.
PostPosted: Sun Oct 10, 2004 6:51 pm
I judge you GUILTY!
I judge you GUILTY!
Whataver language has a good math liibrary.
Maybe Fortran :p
PostPosted: Sun Oct 10, 2004 6:54 pm
Yes.
Fortran.
Fortran and Cobol. Those are your best choices, gamerfreak. You should learn those immediately.
:D
PostPosted: Sun Oct 10, 2004 7:27 pm
since you may or may not get kenshins joke dont learn fortran or cobol.
Learn either qbasic or visual basic, those are your easiest to learn languages (for those who consider them languages).
PostPosted: Sun Oct 10, 2004 7:35 pm
Team Member Top 100
Team Member Top 100
I'd say C / C++.
 Post subject: Re: Small math programs
PostPosted: Mon Oct 11, 2004 5:25 pm
Your TI-83 will do this for you, heck, a sheet of paper can as well. A VB app can do the same thing.
Now, if you want to write your own vector class with overloaded operators...then I'd say C++. :P
PostPosted: Tue Oct 12, 2004 12:05 am
Bitchin' Fast 3D Z8000*
Why does it seem like you ask them same question once a month. :?
An easy solution would be to use Mathematica. Otherwise, I would suggest either Python or Java. As previously mentioned, most languages are fine for simple math.
PostPosted: Tue Oct 12, 2004 12:07 am
Maybe Fortran :p
Making fun of Fortran is all fun and games until you realize that it contains some calc or trig function that is going to cause you severe brain damage to implement in C++ or some other language. :)
PostPosted: Tue Oct 12, 2004 12:09 am
PITA brain damaged languages. Try reading and understanding some old qbasic code and you'll see what I mean.
PostPosted: Tue Oct 12, 2004 7:10 pm
I judge you GUILTY!
I judge you GUILTY!
Gadget, I am of the philosophy of the right tool for the right job.
Writing a mathematically intense application? Use fortran
Need to do som text processing? Usy python/perl
Need to write an OS? Use C/C++
PostPosted: Thu Oct 14, 2004 12:23 am
Good philosphy. ;)
