It is currently Sun May 19, 2013 1:18 am
 Post subject: 3 Multiple Choice C++ Questions
PostPosted: Fri Oct 08, 2004 9:04 am
When parameters are passed between the calling code and the called function, parameters and arguments are matched by:
a. their data type
b. their relative positions in the parameter and argument lists
c. their names
d. they are not matched up at all
Which of the following are valid function calls to the tabs function?
a. fabs(3.5);
b. cout << fabs(3.5);
c. cin >> fabs(3.5);
d. fabs(cin >> x);
e. a and b
What is the value of i after the following function call?
//function definition
int doSomething(int value)
value = 35;
return value;
//fragment of main program
int i=0;
cout << doSomething(i);
a. 13
b. 35
c. 48
d. 0
PostPosted: Fri Oct 08, 2004 3:39 pm
Team Member Top 100
Team Member Top 100
I believe:
B
E
B
Not sure about the first one, though, and I think it might depend on the calling convention.
 Post subject: Re: 3 Multiple Choice C++ Questions
PostPosted: Fri Oct 08, 2004 4:02 pm
a. their data type
c. their names
a. fabs(3.5);
d. fabs(cin >> x);
e. a and b
value = 35;
return value;
int i=0;
a. 13
b. 35
c. 48
d. 0
Ah, what the heck:
1) A
2) E
3) B
As for the first question, I'm guessing on this one as I totally forgot.
As for the second question, the reason why it's A and B is because:
if the function fabs returns nothing, then a call to fabs(3.5); would indeed be legal. Otherwise, if it returned something, a variable of some sorts has to receive the returned value (like x = fabs(3.5); ). Hence, the cout << fabs(3.5) ; is legal.
The second one, duh, it's 35. You pass a value to the parameter "value" yet you initialize the value of "value" to 35, regardless of what number you pass into the function doSomething(). Hence, it's B.
PostPosted: Fri Oct 08, 2004 4:23 pm
Team Member Top 100
Team Member Top 100
Yeah, I'm only really interested in finding what the answer to the first question is, although it seems pretty useless knowledge :)
PostPosted: Sun Oct 10, 2004 3:59 am
Bitchin' Fast 3D Z8000*
B - E - D. ;)
PostPosted: Sun Oct 10, 2004 4:02 am
You might want to review "pass by value".
PostPosted: Sun Oct 10, 2004 8:31 am
Gadget wrote:
You might want to review "pass by value".[/quote
Yeah, it's pass by value. If the function would have been int doSomething(int &value); then it would have been different. Regardless, since the function parameters pass the value not the reference, it will always amount to 35.
PostPosted: Sun Oct 10, 2004 1:45 pm
Let's walk-thru this problem:
Question: What is the value of i after the following function call?
The valueof i. Not the value that is sent to stdout.
int i=0;
At this point, the value of i is 0.
Here we pass a copy of the value of i to the function doSomething, which has a seperate integer variable value, and output the return value of doSomething to stdout. Notice that we have not changed the value of i though. Only passed a copy of the value of i. Therefore, i = 0 regardless of what happens in the function. If this was a pass by reference, then i would be = 35. The output sent to the screen is from the variable value which is equal to 35.
PostPosted: Mon Oct 11, 2004 5:26 pm
Yeah, I didn't pay attention to the question. Oh well, i = 0, no matter, yes. I just didn't read the question correctly. Oh well.
PostPosted: Mon Oct 11, 2004 7:41 pm
Team Member Top 100
Team Member Top 100
Then can someone explain this to me?
My code:
#include <iostream> //function definition
value = 35;
return value;
int main()
   int i=0;
   std::cout << doSomething(i);
   std::cin.get();
My output:
Quote:
35
Compiled with VC++ 2005.
Did I make an error in the code?
PostPosted: Mon Oct 11, 2004 7:45 pm
It is outputting the value returned by the function, not the value of i. Add a cout << i << endl; below the doSomething to get the value of i.
Yeah, I figured you weren't paying attention to the question. :)
PostPosted: Mon Oct 11, 2004 7:46 pm
hehehe... :oops:
PostPosted: Mon Oct 11, 2004 7:48 pm
Gadget wrote:
B - E - D. ;)
Isn't it that monosyllabic, three letter word that programmers never see, but have only heard from significant others/spouses? Wow, I don't even remember what a "B E D" is...
PostPosted: Mon Oct 11, 2004 7:52 pm
DJSPIN80 wrote:
Gadget wrote:
B - E - D. ;)
Exactly my thoughts when I was answering it. Check the time stamp. :)
PostPosted: Mon Oct 11, 2004 7:59 pm
Team Member Top 100
Team Member Top 100
Oh, sorry, I didn't read the question carefully enough!
I was just looking at the output.
