It is currently Sat May 18, 2013 8:32 pm
 Post subject: "google developing"
PostPosted: Thu Oct 07, 2004 3:07 am
7yrs+11,000 Posts
7yrs+11,000 Posts
http://www.google.com/apis/
 Post subject: Re: "google developing"
PostPosted: Thu Oct 07, 2004 6:09 am
eh? You can use Google's API's to scour the web for you, unfortunately, you can't make money off of it nor could you resell it as a 3rd party app (last I checked). It's kind of neat actually, the API is very simple to use.
PostPosted: Thu Oct 07, 2004 9:45 am
It is a beautiful thing. :)
PostPosted: Thu Oct 07, 2004 10:49 am
It is, I've never really found a use for it, so I'm not really up to par about using it. OTOH, I'm looking forward to my migration towards Java Development Environment. Let's just say, it will be interesting.
PostPosted: Sat Oct 09, 2004 8:32 pm
"Take that and wind it back...DJ Wolf got the API to make his booty go whack...!"
Nice. This will integrate beautifully into the web service I'm building at the moment.
PostPosted: Sat Oct 09, 2004 8:36 pm
I've been thinking of modifying it to use it for dynamic product information...say you have a new product, the product name, and the model. You could search the web, but then wrap the results up into a customized page via an integrated XML web control. Not only would you have a direct link to the product from the manufacturer, but also reviews, plus maybe some images...etc.
The problem is the format of the data and the accuracy of the results you pull back...basically filtering.
