It is currently Sat May 18, 2013 3:26 pm
 Post subject: Ahhhh Please help me with simple C++ problem?
PostPosted: Wed Oct 06, 2004 7:51 am
I wanted to learn how to do some simple C++ programming so I bought this beginners book and software. Well the 2nd problem I'm suppose to do is a real bitch. The first one was easy but the 2nd one just confuses the hell out of me. It wants me to "loop" a program but hasn't explained how to do that...some book.
Problem Solving with C++
The Object of Programming
Problem #2
A hospital-supply company wants to market a program to assist with calculation of intravenous (IV) rates. Design and implement a program that prompts a clinician (typically a nurse) for dose as written by the physician, and the desired flow-rate format. The program must:
use a function to collect data and perform calculation for each problem (each type of calculation), returning the answer to its caller.
use a function that displays the menu, and returns the selected menu number to its caller.
output the answer rounded to the nearest whole number (NOT TRUNCATED).
continually re-prompt the user with the menu until the user enters 5 (Quit).
use local variables only.
be well commented/documented and use indentation appropriately.
use descriptive variable and function names.
display an error message if the user enters an invalid menu choice.
repeat until the user indicates that he/she wants to quit (menu item 5).
Here is the equation for problem 1 (drops per minute):
volume (ml) X drop factor (drops/ml)
= drops / minute
time (min)
For more information on this "drop factor" equation, visit: http://www.cybernurse.org.uk/nursing/i_ ... _rates.htm
The program should interact with the user as follows:
INTRAVENOUS RATE ASSISTANT
Enter the number of the problem you wish to solve.
GIVEN MEDICAL ORDER IN: CALCULATE RATE IN:
1) ml/hr and tubing drop factor drops/min
2) 1 L for n hrs ml/hr
3) mg/kg/hr and concentration in mg/ml ml/hr
4) units/hr and concentration in units/ml ml/hr
5) QUIT
Problem: 1
Enter rate in ml/hr: 150
Enter tubing's drop factor (drops/ml): 15
The drop rate per minute is 38.
5) QUIT
Problem: 2
Enter number of hours: 8
The rate in milliliters per hour is 125.
5) QUIT
Problem: 3
Enter rate in mg/kg/hr: 0.6
Enter patient weight in kg: 70
Enter concentration in mg/ml: 1
The rate in milliliters per hour is 42.
5) QUIT
Problem: 4
Enter rate in units/hr: 1000
Enter concentration in units/ml: 25
The rate in milliliters per hour is 40.
5) QUIT
Problem: 5
Goodbye...
I didn't buy the solution manual for this book because I already spent a crap load of money for the book and software. It does give me this as a starting point but its a little to complicated. I understand parts of it but not all of it. Can anybody tell me what to do next or just solve this problem so I can see what you did? I've been trying to figure it out for days!!!! Bout to throw this programming crap away.
#include <iostream>
using namespace std;
int main (void)
int task = 0;
double rate = 0.0;
task = getProblem( );
if (task == 1)
else if (task == 2)
int getProblem (void);
double calcDropsPerMinute (void);
double litersToMlPerHour (void);
double calcRateFromWeight (void);
double calcRateFromUnits (void);
void displayRate (double rate, int task);
int main (void)
cout << "INTRAVENOUS RATE ASSISTANT \n\n";
double rate = 0.0; //Will contain the calculated rate
int task = 0; //Will contain the users menu response
bool done = false; //Flag used to tell when user quits
do
if (task == 1)
rate = calcDropsPerMinute( );
else if (task == 2)
rate = litersToMlPerHour( );
else if (task == 3)
rate = calcRateFromWeight( );
else if (task == 4)
rate = calcRateFromUnits( );
else if (task == 5)
done = true;
if (!done)
displayRate(rate, task);
}while (!done);
cout << "Goodbye.\n";
return 0;
PostPosted: Wed Oct 06, 2004 8:27 am
the solution is ez to code, but it would take more time than i want to code and test the code. However, you might want to get started with this tutorial:
http://www.intap.net/~drw/cpp/
It seems like the problem you are solving is exercising your knowledge on calling functions and loops.
I could probably be better help if you had more specific questions about the code.
PostPosted: Wed Oct 06, 2004 8:37 am
Hah I wish I had more specific questions, I just don't know where to start, it would be awesome if you could do part of it or start it but I can understand if you don't.
PostPosted: Wed Oct 06, 2004 6:44 pm
Team Member Top 100
Team Member Top 100
Please use code tags!
#include <iostream>
//you had a bunch of junk here.  I'll assume it was just a copying error
int main (void)
cout << "INTRAVENOUS RATE ASSISTANT" << endl << endl;//use stream operator endl rather than a newline character.
//endl also flushes the output stream.
do
    if (task == 1)
    else if (task == 2)
    else if (task == 3)
    else if (task == 4)
    else if (task == 5)
    done = true;
    if (!done)
}while (!done);
cout << "Goodbye." << endl;
cin.get();//gives the user a chance to read the output before the window closes
//purely optional, just nice if you're not running the program from a terminal
return 0;
int getProblem(void)
    //this will print the menu and get the menu response
    int response;//the user's response
    cout << endl <<"GIVEN MEDICAL ORDER IN: CALCULATE RATE IN:" << endl << endl;
    cout << "1) ml/hr and tubing drop factor drops/min" << endl;
    cout << "2) 1 L for n hrs ml/hr" << endl;
    cout << "3) mg/kg/hr and concentration in mg/ml ml/hr" << endl;
    cout << "4) units/hr and concentration in units/ml ml/hr" << endl;
    cout << "5) QUIT" << endl;
    cin.get(response);//get the response
    cin.ignore(1000000, '\n');//ignore everything to the newline, so we don't get a bogus value next time
    return response;
I did 1 function for you. Does it make a little more sense to you now?
PostPosted: Thu Oct 07, 2004 9:11 pm
Yes thanks alot. I got my code to work now.
Here's the final code that worked:
#include <iostream>
int menu(void);//Menu is ran so user can select their choice
double prob1(void);//Declares prob1
double prob2(void);//Declares prob2
double prob3(void);//Declares prob3
double prob4(void);//Declares prob4
int main (void)
cout << "INTRAVENOUS RATE ASSISTANT\n\n";//Title at begining of program
int task;//Selection chosen for if statments
do//Runs users task and repeats menu if user selects correct value
task = menu ();//Tasks are brought in so user can decide which one to run
if (task == 1)//Runs task 1 and returns value
cout << "The drop rate per minute is "<<prob1()<<"."<<"\n\n";
else if(task == 2)//Runs task 2 and returns value
cout << "The rate in milliliters per hour is "<<prob2()<<"."<<"\n\n";
else if(task == 3)//Runs task 3 and returns value
cout << "The rate in milliliters per hour is "<<prob3()<<"."<<"\n\n";
else if(task == 4)//Runs task 4 and returns value
cout << "The rate in milliliters per hour is "<<prob4()<<"."<<"\n\n";
}while(task !=5);//Runs do statment as long as task does not equal 5
cout <<"\nProblem: 5\n";//Quits program when task = 5
cout <<"Goodbye...\n\n";
system("PAUSE");
return 0;
int menu(void)
int task;//Declares users task
cout << "Enter the number of the problem you wish to solve.\n\n";
cout << "GIVEN MEDICAL ORDER IN: CALCULATE RATE IN:\n\n";
cout << "1) ml/hr and tubing drop factor drops/min\n";
cout << "2) 1 L for n hrs ml/hr\n";
cout << "3) mg/kg/hr and concentration in mg/ml ml/hr\n";
cout << "4) units/hr and concentration in units/ml ml/hr\n";
cout << "5) QUIT\n";
cout << "Enter your selection: ";
cin >> task;//User enters their task
return task;//Returns task to main
double prob1(void) //First menu option, User types 1 the following will be used
double mlhr=0.0, dropfactor=0.0, droprate=0.0;//Declares variables for prob1
cout << "\n\nProblem: 1\n";
cout << "Enter rate in ml/hr: ";
cin >> mlhr;//User enters ml/hr
cout << "Enter the tubing's drop factor (drops/ml): ";
cin >> dropfactor;//User enters dropfactor
cout.setf(ios::fixed);
cout.precision(0);//Numbers are rounded to nearest whole number
droprate = ( mlhr * dropfactor) /60;//Formula for calculation
return droprate;//Droprate returned to main
double prob2(void) //Second menu option, User types 2 the following will be used
double hours=0.0, droprate=0.0;//Declares variable for prob2
cout << "\n\nProblem: 2\n";
cout << "Enter the number of hours: ";
cin >> hours;//User enters the number of hours
cout.precision(0);//Rounds to the nearest whole number
droprate = 1000/hours;//Formula for calculation
return droprate;//Returns droprate to main
double prob3(void) //Third menu option, User types 3 the following will be used
double mgkghr=0.0, kg=0.0, mgml=0.0, droprate=0.0;//Declares variable for prob3
cout << "\n\nProblem: 3\n";
cout << "Enter rate in mg/kg/hr: ";
cin >> mgkghr;//User enters mg/kg/hr
cout << "Enter the patient weight in kg: ";
cin >> kg;//User enters patient weight in kg
cout << "Enter the concentration in mg/ml: ";
cin >> mgml;//User enters concentration in mg/ml
droprate = (mgkghr * kg)/mgml;//Formula used for calculations
double prob4(void) //Fourth menu option, User types 4 the following will be used
double unitshr=0.0, unitsml=0.0, droprate=0.0;//Declares variable for prob4
cout << "\n\nProblem: 4\n";
cout << "Enter the rate in units/hr: ";
cin >> unitshr;//User enters rate in units/hr
cout << "Enter the concentration in units/ml: ";
cin >> unitsml;//User enters units/hr
droprate = unitshr/unitsml;//Formula for calculation
PostPosted: Sun Oct 10, 2004 2:35 pm
Bitchin' Fast 3D Z8000*
Gigahertz, please use the code tag in the future. No one wants to read a bunch of unformatted code. Thanks.
PostPosted: Sun Oct 10, 2004 3:41 pm
Does the code tag reformat text, or simply present with nice retro-green styling?
do {
if (indent==true)
Gadget.IQ=genius;
else
Gadget.IQ=submoron;
} while (code.tag != pretty)
do {
if (indent==true)
Gadget.IQ=genius;
else
Gadget.IQ=submoron;
Nope ... just pretty. Still ... it helps us all if you use the [code] tags. :D
PostPosted: Sun Oct 10, 2004 9:02 pm
Smart ass. :)
Gigahertz, if you haven't used proper indentation, do so. ;)
