It is currently Mon May 20, 2013 9:03 pm
 Post subject: "Dynamic" HTML Color Table(s)
PostPosted: Wed Jul 26, 2006 4:40 am
I am working on one because I always seem to never be able to find the color that I want... SO...
http://www.daobesys.com/color.asp
http://www.daobesys.com/color.asp?order=2
I have another version of it that I am working on... so this is a WIP for now. Should be handy to have though.
PostPosted: Sat Jul 29, 2006 1:19 pm
Hey, started playing around in javascript again, but It's difficult. I'm trying to limit myself to methods that work in both ie AND firefox, without having to check to versions and write the same thing twice. Real lack of editors out there it seems for js. Ah well. Just doing this to get back into the swing but i've encountered one annoyance - well several.
onclick for buttons doesnt work in firefox, I have to use a return
onclick="recompute(); return false;"
then i found out my radio buttons can't be read normally
if (corn[0].checked){
        ulr=document.getElementById("vred").value;
        ulg=document.getElementById("vgrn").value;
        ulb=document.getElementById("vblu").value;
Using ie it works, using firefox, I get "corn not defined" using the javascript console. Anyone know how i'm suppossed to access a radio button's value in firefox js?
http://beomagi.ath.cx/colorpicker.html
PostPosted: Sat Jul 29, 2006 1:44 pm
EUREKA!
if (document.getElementById("cn1").checked){
where each radiobutton has a different id- name="corn" but id="cn1".."cn4" horrible way to do it if it's a long array, but this seems to work for now.
PostPosted: Mon Jul 31, 2006 6:13 am
Beomagi wrote:
EUREKA!
Yep. that is how most radio button collections work... I think in .NET there is a control that actually is a collection of radiobuttons (radio button list) and I think you can access them by their numerical index.
I do have a Javascript version of this page, but this one is written in pure classic ASP. It runs faster as it is handled server-side rather than client side. It works better for this as it doesn't require any client interaction to generate the table as your color picker would do.
