It is currently Sun Apr 26, 2015 1:00 am
 Post subject: CSS - background-image
PostPosted: Mon Sep 27, 2004 2:08 am
Problem solved, but I'll leave it here with the solution in case anyone else has the same issue.
I'm having a strange, and very frustrating problem.
Culprit:
http://24.57.167.209/sda/
Is passes the W3C validator, but I can't get the background image to show! The headerbg.jpg file is a valid path, and is shown on the page using img tags. When trying to set it as a background, it doesn't seem to work. What am I doing wrong?
[edit]
Here's the css.
body
    background-image: url("headerbg.jpg");
    background-repeat: repeat-x;
    background-position: 50% 100%;
    margin: 0;
    padding: 0;
p {
padding: 0 15px;
p:first-letter {
font-size: 120%;
font-weight: bold;
[edit2]
Found the problem, was a silly one. I thought the css file loaded from the original source files directory. Nope, loads from the css file.
PostPosted: Tue Sep 28, 2004 6:21 am
Just so you know the url is giving a Page cannot be displayed error.
