It is currently Fri Feb 27, 2015 9:47 pm
 Post subject: Front Page
PostPosted: Sun May 28, 2006 12:33 pm
I got Visual Basic C++ off of ebay.
When I tried to install it, it said that I had to update my copy of Microsoft Frontpage. It could not install it because it said it was incompatible with any O/S over windows 2000. When I tried to find a version compatible with XP on Microsoft, it said I could get a trial for Frontpage 2003. All I want to do is get my copy of visual basic running.
Does anyone know where I can get a win XP compatible version or am I out of luck?
Thanks
PostPosted: Tue May 30, 2006 10:23 pm
Why are you paying money for M$ VB when GNAVI and DevCPP are free? :wink:
PostPosted: Fri Jun 02, 2006 11:34 am
good question, but are there any ideas for my question???
PostPosted: Fri Jun 02, 2006 11:37 am
No, I personally don't because I only program in open source developing programs. And evidentally, neither does anyone else because noone else has replied to your thread :(
 Post subject: Re: Front Page
PostPosted: Fri Jun 02, 2006 12:25 pm
Monkey Federation (Top 10)*
Thanks
Your post is confusing (and in the wrong folder). I'll make some assumptions and you let me know what is right/wrong.
Your OS is XP
You bought VB and tried to install it
It would not install because your using a Office 2000 package?
If I were you, I'd delete Front Page completely off your machine and then install your VB package. You have Notepad. You don't need Front Page.
PostPosted: Fri Jun 02, 2006 12:35 pm
Malware specialist
Malware specialist
Honestly, I don't think you should have bought that. Instead you could have got the express edition of what you needed from Here. Oh and best of all, it's free.
PostPosted: Sun Jun 04, 2006 4:30 pm
Team Member [Top 500]*
This is in part what is confusing:
The current versions are Visual Basic.NET and Visual C++.NET and they are two seperate packages.
Hackman makes a good point. If you are going to go that route, the visual studio express edition should fit the ticket. I would give that a look.
I don't quite understand the Front Page issue either. I know FP 2000 and up will run on XP. Currently in addition to Visual Studio.NET (2003 Version) I have Visual Basic 6.0 running on this machine with FP 2002 but they all ran with FP 2000.
What version of Visual Basic or Visual C++ did you buy?
Ron
