It is currently Sun Apr 26, 2015 1:23 pm
 Post subject: Is there a better way to obtain timestamps in Java?
PostPosted: Fri Sep 17, 2004 9:58 am
Is there a better way to obtain timestamps in Java? I need to do some performance test in Java, and am using
Calendar.getInstance().getTimeInMillis() to grab timestamps. Unfortunately, this method seems to have some overhead. So I am just wondering if there is a better way of obtaining timestamps in Java than using Calendar. Thanks.
PostPosted: Fri Sep 17, 2004 5:40 pm
Team Member Top 100
Team Member Top 100
The most accurate way to gain time information on an x86 system is to use the RDTSC assembly instruction. This will give a 64-bit value containing the current tick count. This isn't supported on all processors, but I've found it to be useful.
However, I do not program in Java, and I do not know if there is a way to use assembly in Java. Even if you cannot, though, you could always write a dll for use with your program.
You can then get the processor speed and you can see how many ticks to one nanosecond, one milisecond, etc.
Here's a reference:
http://www.math.uwaterloo.ca/~jamuir/rdtscpm1.pdf
PostPosted: Fri Sep 17, 2004 6:25 pm
hi kybo,
really appreciate your reply. Unfortunately I cannot use assembly instructions. Although at the moment, our test bed is an x86 machine, but later on, we will move on to some different architecture (could be solaris, but not sure yet), and we probably have to do another performance test there. That is another reason why we used Java in the first place.
If we write an DLL, then yes, we can always use the JNI, but I don't know how much overhead would be involved in that. It may be faster, but could also be much slower than using the Calendar method.
Any how, I really appreciate your input, especially the link to the PDF. Maybe not this time, but sooner or later, I will need to use the RDTSC instruction.
thanks!
eman
PostPosted: Fri Sep 17, 2004 7:58 pm
Team Member Top 100
Team Member Top 100
Then can you put the function you wish to benchmark in a loop (to execute it say, a thousand times), and then divide by the milisecond timestamp you have?
PostPosted: Fri Sep 17, 2004 8:24 pm
Does the java.util.Date class not do what you need?
http://java.sun.com/j2se/1.4.2/docs/api/
 Post subject: Re: Is there a better way to obtain timestamps in Java?
PostPosted: Sat Sep 18, 2004 1:43 pm
Bitchin' Fast 3D Z8000*
Not sure what you mean by overhead, but you can use System.currentTimeMillis() to do this type of thing.
public class TimeStamp {
    public static void main(String[] args) {
        //start timer
        long time1 = System.currentTimeMillis();
        //do something
        //end timer
        long time2 = System.currentTimeMillis();
        System.out.println("time2:  " + time2);
        System.out.println("time1:  " + time1);
        System.out.println("diff:   " + (time2 - time1));
        System.exit(0);
PostPosted: Fri Sep 24, 2004 3:37 pm
I can't believe I forgot to mention it. Java 1.5 has a more accurate timer now. I haven't used it, but you might want to check it out.
